Going down one of my rabbit holes just to satisfy my curiosity. Just for the heck of it, I put my Rem 700 action with the scope rings installed on the mill and checked them for parallel and alignment. What I found out was shocking! Nothing with the rings was even close to be in line. The picatinny rail had a twist, the rings were out of alignment over .040" and not parallel with the bore. So on a hot muggy afternoon I turn on the AC begin to mill my own rail while it is mounted on the receiver.
One of the challenges on the receiver is two different radii and two different heights. Thank god for a cad program to help me get that figured out!
I wanted the scope tube to bisect the bore so I measured the scope mount after getting it to full profile on one side and measure the center of the rings. Got the number and finished milling it to spec but in the end I was still .034" from perfect center. Should have paid better attention in geometry back in the school days. But the windage turret will dial that out and I am happy that the mount is within half a thou from ring to ring. No binding on this scope! Also corner rounded the edges of the mount rings to keep from digging into the scope tube.
You can see the amount of offset to try and center the tube but it really should have been a bit more.
