M7040 3 point weakens throughout the day
Mikec575
62
11
My M7040 3 point will pick up implements in the morning and after lunch I have to bring the RPM up to get it to lift the same weight it lifted before lunch at an idle.
any suggestions?
comparison- M7060 will lift the back of my gooseneck no problem and the M7040 barely lifts it when bringing the RPMs up.
7,331
any suggestions?
Something in your hydraulic system is bypassing oil when the oil warms up and thins out. The two main suspects are the 3pt lift cylinder and/or the hydraulic pump. Do you have a loader on the tractor?
Mikec575
62
11
any suggestions?
No sir I do not have a loader on it
7,331
I would suggest a couple simple tests. Conduct each test before the oil is warmed up and again after its warmed up and you are loosing lift.
  1. Check for cylinder bypass. Remove the small return hoses on the lift cylinders and check for fluid when you raise a heavy load. Ideally there should be none.
  2. Measure pump pressure. Plug a pressure gauge into your rear remote and operate the control lever to get a pressure reading. Factory specification is 2770 PSI.
Mikec575
62
11
How can I go about seeing if it is bypassing in the steering system?
I am only getting about 1300 psi at the rear remote.
I took the hoses off the rear lift cylinders and there is no fluid coming out of the cylinders.
7,331
The PS has its own pump and is a different circuit.
I will have to do a little research on the M7040 plumbing to see where to go next.
7,331
There arent many places to use as test points in that plumbing.
Kubota wants you to use a "special tool" (adapter block) to connect a flow meter to the outlet flange on the pump.
There is also a joint in the delivery pipe that looks like you could hook up there with a simple hydraulic fitting. That would be my first choice.
In either case if you dont happen to own a high dollar flow meter you also need to construct a pressure test rig from some hose, a needle valve and a pressure gauge. Pretty simple. You up for that much work?
Mikec575
62
11
I am up for the work. It's having the knowledge to do it without deadbeading and damaging the brand new pump.
7,331
Sorry I didn't mention that earlier. When I have mentioned about a new pump or part everyone always says you still need to test the pump
Ask "everyone" what they expect to learn by testing the new pump.
Lets backup a minute.
When you tested pressure at the remote did you test with the oil cold and then again when hot. How do those two numbers compare?
Did you have engine speed up around 2000 RPM when measuring pressure?
Mikec575
62
11
I only tested it cold.
Yes sir I was around that 2200 rpm when getting that pressure.
also did I mention I swapped the relief valves just to rule that out as well. The 7040 relief valve didn’t seem to increase pressure when trying to adjust it so I just took the 7060 that has good pressure and put it in the 7040 with no change in pressure.
no I did not put the 7040 (low pressure tractor) into the 7060 ( good pressure tractor)
7,331
No, you did not mention any of that and this is not adding up.
You only had 1300 PSI cold yet you say the lift works fine when the oil is cold. How fo we reconcile that?
I think we need another pressure test with both hot and cold oil before doing anything else. The pressure gauge should be plugged directly into a remote, engine at 2200 RPM, and remote lever moved and held full open for at least 5 seconds.
5,515
2,228
I've had a relief valve in the position control valve assembly) stick and cause this exact same thing. I did 8 or 10 of them before I left the kubota business. On cab models you have to lift the cab a little bit to get the position control valve assembly out. But you need to be able to diagnose it properly so you're not unnecessarily removing parts. Out of those ones I had to do, 100% of them had TSC hydrualic fluid in them. Just saying.
7,331
That would not cause pressure to be 1300 PSI at the remote outlet.
7,331
So cold the pressure is 1600 and hot oil the pressure 1300.
Not a big difference. This does not look like a temperature problem as much as a fundamental loss of pressure. You are at least 1000 PSI low.
I guess we will have to test ahead of the relief to see if thats the source of the pressure loss. Its not a complicated procedure - the hard part is figuring out what fittings we need to tap into the delivery pipe.
Mikec575
62
11
Are you referring to the fittings under the right foot plate. I have one of the loop pipes that fits it so I can just take that to my hydraulic hose guy and see if we can’t make something to hook my gauge too. There is a second discharge pipe coming off this pump so would that be deadheading? Do I need to figure out how to keep the flow going through the loop?
7,331
That is perfect!! You are a step ahead of me.
The other pipe is a different pump and circuit for PS.
My guess is that pipe is JIC 8. If you have a fitting or hose in that size see if it matches.
We will construct a test rig to avoid deadheading the pump. What does your pressure gauge look like?
