Hooking up third function, rear remotes, and a backhoe line.
6,272
So the P is (B), T is (D), and PB is (C)?
Is that a kubota kit? Mine is from summit. I see your point about maybe being cramped but I'll just have to cross that bridge when I get ther as this backhoe mated to this machine will be a one off.
Thats a picture of the OEM remote outlets. The valves are actually under the seat and they are operated by levers next to the right side of the seat.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
Beaverdam, Virginia
Help! I just tried hooking up the backhoe since I routed it the way you showed and as soon as I hook it up and start the tractor its like the pump is working and the backhoe has zero function, it even takes away some loader movement.
6,272
You crossed something in the plumbing. Or perhaps one of yoir remotes is not in neutral. Sounds like you have the neutral circuit blocked.
6,272
Routing is correct according to your diagram, I've looked it over many times now, how would I know which remote isn't neutral?
That was just one possibilty. Disconnect the back hoe and loop the tractor side hoses together. You may not have the backhoe couplers fully connected. Happens pretty frequently.
ayak
L3301 HST
Feb 16, 2018
729
1,080
WV
Did it work in its most simple configuration? Add stuff in one by one and test functionality. Also keep in mind, the 3-point hitch lever (on right side of your seat)-MUST be all the way forward (down) anytime the backhoe is in use.
6,272
When I reconnect the couplers on the tractor it works fine, as soon as I hook up the hoe it acts up
You have found the problem and its not your new plumbing.
What that tells you is there is no neutral flow through the backhoe valve. Make sure ALL of the backhoe valves are in neutral.
6,272
One though I do have is why did it work with the previous routing
This failure has nothing to do with the routing.
With the hoe disconnected everything else works.
With the hoe connected nothing works including ths hoe.
The circuit through the hoe is the problem and thats either a spool out of position or a coupler thats not fully connected.
ayak
L3301 HST
Feb 16, 2018
729
1,080
WV
Did the BH77 work ok prior to the project start? Also, you mentioned the BH77 couplers are now flat-faced. Any chance during that mod that they were mistakenly switched between their intent as ‘inlet’ and ‘outlet’?
Also, did the comment about the three point lever in the forward(down) position make sense?
6,272
Good questions but the 3pt lever is clearly not the problem. If it were the problem would still be present with the backhoe out of the circuit.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
Beaverdam, Virginia
@TheOldHokie @ayak
Ayak, your question provoked thought, while I don't have the bh77 but rather a bradco 609, I still went ahead and swapped connectors on the hoe and BAM! It all works now. Dan, thanks for hanging in there with me! Routing is right, connectors were swapped on the hoe, that's probably why it worked with my first Routing. Thank you both!
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
373
Seattle, WA, USA
Here is the outlet block on your tractor.
Here is the proper plumbing with ports and flow paths labeled.
[EDIT] I just read the Kubota service bulletin that someone posted a link to. My understanding is that the o-rings in this specific application (i.e. the tank port of the BH) aren't designed to be back pressured and will cause leaks when connected using OP's design.
[/EDIT]
Dan--
Question: What does the PB port on the outlet block do? I'm asking because it seems like it would be for powering some downstream implement. In which case, doesn't the backhoe's tank port still see a pressure every time that implement is used? I'm trying to get a better understand of what the design rule is.
thanks,
Eric
