1980 B6100 4x4 - Looking for loader.
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
The response from the other guy was not in my view worth anything of any value. Besides that being a condensending A-Hole doesn't sit well with me.
He may have been a little tongue-in-cheek with his response, but calling people names is not appropriate either.
His point about the rarity and difficulty finding a used OEM loader 40 years later is valid. It crops up here often, as a search of past posts will show. Few people want to sell a loader separately, and sometimes the only way to get a loader is to buy the whole package and sell your existing tractor. I was in the same boat when I acquired my tractor. After a long and fruitless search I ended up building my own as have many others too.
That is not to say it is impossible to find one. Occasionally unicorns roam free. My backhoe was one such barn find and there is a current thread from someone who stumbled upon a used loader (but lacking the required subframe). Good luck in your search, you might get lucky.
Hugo Habicht
G1900
Jun 24, 2024
1,540
2,232
Ireland
See post #10 ;)
He is lucky. Very lucky, I'd say :giggle:
Would you have pictures of your loader build, or a link to a thread maybe? I certainly will never be able to find a loader for my tractor lawnmower, so I'd be interested seeing DIY solutions.
Swede1962
B6100D 4x4
May 3, 2025
78
44
Overland Park, Kansas
You spent quite a bit of time writing here restating what’s already been said. We”re all big boys here. The guy with the snarky attitude got what he deserved from me as far as I’m concerned. Not sorry, nope not at all for my response. If you can’t say something positive, keep it to yourself. I understand his point but I also subscribe to the philosophy of positive reinforcement, not negative. Good luck to you in all your endeavors. 👍
Swede1962
B6100D 4x4
May 3, 2025
78
44
See post #10 ;)
I started a thread under “Projects” called 1980 Kubota B6100D restoration. I’ll intend to try and keep it updated with pictures as I move thru the process. 👍
7,621
You're on the path!! The joy stick control valve will make a nice addition, and the front clutch in good condition is REAL fortunate.
I found my loader in Bee Bee Ark. Left early and it was an all day trip. I had the seller give me some very specific measurements before I left. Loader had a 5' bucket so it fit nicely into my PU bed. It was nice to net have to pull a trailer.
Following Bill's picture you'll have this thing going before long! Have fun.
For anyone fabbing up a loader frame, probably the most important part is the bar that goes back to the rear axle from the loader tower base. That is what keeps it all from turning into a scrap pile.
Swede1962
B6100D 4x4
May 3, 2025
78
44
I have to source a drive that goes into the spline shaft in front for the pump. I seen it somewhere along with spool valves etc. When that time comes I’ll find it again. Currently bead blasting 45 year old wheels and getting them ready for new tubes and tires. 😁
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
402
179
Southern Worcester County, MA
I drove 380 miles each way. Yup, 760 miles which turned out to be a 17 hour day. Broke a brake line on my old Jeep which the seller helped me repair. Couldn’t ask for a better bunch of folks to deal with. But in the end I have a B219 loader that is in the back excellent condition. 👍
Wow, that's pretty awesome! Its a legit needle in a haystack! I'm glad the folks were super nice too. Nothing worse than dealing with knuckleheads
3,541
Have you seen the photos Lil Foot has of the subframe he built? These pic's will explain it like a picture menu at McDonalds! :LOL:
Correction: That pic is the stock factory subframe. I did not build it. Wish I had. :)
3,541
Nope, not me.
Barts.
This thread, post #24
Swede1962
B6100D 4x4
May 3, 2025
78
44
Try calling 1980.
A loader will cost more than that tractor. Sorry for the reality check.
Did I remember to send you pictures of the loader that 1980 sent to me? If I did, sorry for the duplicates.
nave.lb
B7100-D backhoe/loader & B7100HST-D W/tiller/box/auger
Sep 5, 2022
35
kansas
Found a real nice shape Kubota B219 loader in Oklahoma. Brought it home yesterday. Will build a subframe and re-hose the loader with a pressure gauge and return filter as well. The front spline drive for the pump is in great shape. I found a vendor for the drive attachment and pump. Will also be replacing the 2 lever system with a single 2 spool joy stick for easier operation. Things are looking up around here. 👍
Nice! I found my gear drive 7100 and loader in Oklahoma as well. Did you replace the original valve yet? If so what did you end up using?
