Up a creek
Thatbrokeford
Kubota mx5200
May 22, 2025
Ok guys was running my dads mx5200 for most of the day, shortly before coming in the tractor would barely move forward in first even at high rpm. The problem consisted all the way to the barn. Anyone have any ideas before I break out the ball peen hammer out of frustration, it’s been hot today lol. Thanks in advance
Fedup
338
130
Winchester
Dry clutch tractor? Suddenly won't move? You've checked for pedal free play, right? A slipping clutch is always the first thing that comes to mind with that symptom.
10,108
Any regen indicators flashing, any beeps. Could be in limp mode?
Thatbrokeford
Kubota mx5200
May 22, 2025
No play in the clutch and no regen lights at all, will move in all 4 gears in low but will barely budge in first gear high range. Always been supper easy on the clutch , new clutch was also installed 4 years ago.
JasonW
582
356
Al
Clutch pedal adjusted correctly? Will it move in 2nd high range?
JasonW
582
356
Al
How many hours are in it? How many hours did the first clutch last?
#40Fan
470
322
Something would have to be wrong to lose a clutch at 280 hours and now, 140 hours later, it does sound like the same thing.
Can you smell anything "burnt" around the bell housing/back of engine?
Thatbrokeford
Kubota mx5200
May 22, 2025
They replaced it while I was still on the road working consistently so I’m at a loss as to why they replaced so early, no burnt smell anywhere on the equipment. Trans doesn’t sound like anything broke lose inside either.
3,345
1,766
You have no free play when you push down on the clutch pedal?
You should have just under 1 inch of free play. If you have none, the pressure plate is not clamping the disc tightly to the flywheel.
If you keep running it like that, it will get warm and fuzzy also!!
Thatbrokeford
Kubota mx5200
May 22, 2025
Yees absolutely no free play , the clutch peddle is tighter that dicks hat band. Looks like I’ll need to figure out the adjustments
Old Machinist
May 27, 2024
581
684
NE FL
Stuck Brakes?
Does the engine rev okay or sound labored?
Have you cleaned out the radiator and screens?
Thatbrokeford
Kubota mx5200
May 22, 2025
Stuck Brakes?
Brakes seem to be in good working order, revs just fine doesn’t sound labored at all. I clean the screen and radiator before and after each use. Im pretty anal about maintenance on all my personal equipment so I tend to follow the same when using others
JasonW
582
356
Al
Id like to point out the clutch adjustment is considered maintenance.
Orangeglow
2015 BX2370
Jun 19, 2014
374
188
Prescott, Ontario
I,m kinda confused, If you clean the screen and radiator before and after each use, you should just have to clean it after each use, not before as it should already be clean.
lynnmor
B2601-1
May 3, 2021
1,702
1,497
Red Lion
Apparently there is another operator, perhaps his Dad.
SDT
multiple and various
Apr 15, 2018
3,399
1,180
SE, IN
"New clutch."
This is a red flag and an area that I would suspect firstly after verifying proper operation of the engine.
Does the engine appear to operate properly, or does it bog down when attempting to move? Any white smoke?
If white smoke, suspect fuel delivery, e.g., clogged filters, failing lift pump, etc.
Thatbrokeford
Kubota mx5200
May 22, 2025
I
It is something I’ve always done, even though I know it’s been cleaned after the last use I still make sure there is nothing in there before the next
