Stupid moments and a new tractor.
Blue2Orange
Apr 3, 2025
339
234
Bayview Township
Downsized from a compact NH to the Kubota BX. Stupid moments = events that should not occur.
1st are you that stupid moment. NH had a single rocker pedal. Brake pedal positioned where the forward pedal is on the BX. When needing to stop going in reverse I hit the BX's forward pedal. Bit of a jerky stop. At least I didn't hit what I would of if continuing in reverse. Enough seat hours now on the BX that this moment shouldn't t happen.
3rd moment. Yesterday while spreading new gravel on the driveway all of a sudden could barely move in reverse. Back to garage thinking. Poo. Looked down. The knob that keeps the grill attached had fallen off. Rolled under the reverse pedal preventing full movement. Not fully tightening the knob was moment #2. Luckily the knob didn't end up somewhere on the driveway buried under new gravel.
2,976
Well at least you didnt drop a large log on your hood and place a dent in it........ within HOUR 1 !!!!!! BTDT
Reactions: 6 users
6,486
When I saw the thread title I was willing to bet that you were about to describe how you took out the garage door header with the ROPS. That will come...someday. ;)
7,186
Heck - - I had the rear wheels WAY off the ground within first 2 minutes of use of the loader.... :oops:
Thankfully kept rubber side down. I had some operating experience which helped. Had to remember it wasn't a Case 580K....
Off topic a little, buddy used to joke he rode his Kawasaki behind the group of his Harley Davidson friends.
He would pick up the parts that fell off the H-D's....:oops:
I bought a new Harley in 2005. First ride, I was leaving a town and accelerating.
Missed a shift...twice...thought lack of practice.
Look down and my shifter peg fell off!!!! Bike had 10 miles on it.....:oops:
Could hook the shifter arm with my shoe but was a challenge.
Rode 10 more miles home and stopped at my local hardware store. Owner and I fashioned a cheap and rustic peg out of 1/4" pipe nipple.
Used it for several months and kept it 20 years....;)
William1
BX25D
Jul 28, 2015
1,336
523
Richmond, Virginia
Done it once with the Kubota. Fortunately, it was just mangled metal cover over the header and I had a guy coming in a week to do other trim work so....
And I did it once with the wife's car (garage door was not fully opened.) That was a $1,500 insurance claim!!!
New shop has a 10' high door. I still look as I go under to make sure the 2' clearance is enough.....
6,486
Ditto. I got my old BX23 stuck in the garage door. Took me about 10 seconds to figure out why I couldn't move forward with the tractor any further. Thought I had a transmission issue. Then I looked up. ROPS was wedged under the garage door header. Dropped the air in the rear tires to get it loose. :(
Blue2Orange
Apr 3, 2025
339
234
Bayview Township
More or less did that with compact NH. Had ~1cm of clearance below the garage door bottom lift/pull down handle. One cold winter day the ROPS clipped it somehow messing up the torsion spring system. Cleared the driveway and then proceeded to reset the torsion spring by trial and error. BX is tiny. Plenty of clearance above the ROPS. Plus I removed the handle on the garage door. To short to reach and a pain in the back bending over to pull up. Useless handle except for catching ROPS.
Blue2Orange
Apr 3, 2025
339
234
Bayview Township
4th moment this morning. Normally I don't run the fuel level below 1/4 level. Had ~3/8 of tank of fuel left. More driveway work using the FEL and dirt bucket to fill and back blade my dips and rolls. After a bit of time fuel idiot light kicked on. Gauge was close to empty. 100 feet from garage. Back in the garage the gauge read ~1/8th. Realized going up a steeper incline the gauge goes down and the light goes on. Also tilting to starboard (users right) it drops.
Guessing not good for the fuel pump when fuel level is low. In the future will definitely try keep at least 1/2 tank full and refuel before reaching 1/4 tank. Small tractor. Small fuel tank. 1/4 of small is not much fuel.
7,186
Don’t ever trust the fuel gauge.
I don’t know the changes/improvements between my BX2360 and your BX2380.
If my BX2360 fuel gauge gets off “FULL”, it will often take nearly 2.5-3 gallons of fuel which is half the rated capacity.
Been that way 12 years.
I usually fill it as soon as the needle starts tipping off FULL.
I would never let it down to a 1/4 tank on the gauge.
If you draw a bunch of bugs, algae and other crap from the tank and into the lines, filter, and lift pump you’re done.
Could take a lot to get it running again.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
420
475
NE Ohio
Don’t ever trust the fuel gauge...
My BX2380 is the same way.
4,758
Well dont feel to badly, I know a guy that had a yellow tractor with no ROPS, and for years use to just push, low branches out of the way, never a problem....... THEN ONE day this guy bought an orange tractor with a ROPS, and mowing the same places he mowed for years with the old tractor with never a problem pushing low hanging fruit branches out of the way. And with out thinking, pushed up a low branch, only to find it and his arm entangled in the branch and the ROPS. That resulted in a one handed drive to the ER , and he came home with his arm in a cast.
bbxlr8
Mar 29, 2021
446
308
Eastern PA
Got that t-shirt as well. In my case, I was super paranoid in the beginning, and you think you have it down to habit... Until a long day in the seat using BH & loader into late evening (read as dark) then getting a surprise thunderstorm. The shed is/was pretty well built and gave a bit but didn't crush.
I'm pretty sure I cracked a beam or two :oops: . "Tapped" it again after a few similar days - Not my sharpest moments!
3,345
Unfortunate thing! How long before the cast came off your arm?
9,062
I ripped the right rear light off my Massey.
It's mounted to the outside of the rops and a tree limb got it 🙄🙄
Sidekick
Jul 29, 2023
1,164
1,637
N.Y,
How about you getting off your BX to open the garage door. As walking towards the door you hear the emergency break release on its own. BX is rolling down the hill towards the still closed door. Jump on it and try to smash the brake pedal to the floor to stop it but with only one leg on the tractor wind up smashing down the forward pedal. Here we go through a 12 x 12 insulated garage door ripping off the 2 bottom sections and bending others with the rops. It hurt me more then the BX. Lesson learned, don't trust a BX parking brake. Got the door bent back and on the rollers so its usable but gonna take $3k to make it pretty again 😬.
Reactions: 6 users
4,725
Wow....@Sidekick that makes my "Water-Gate cover up" story seem insignificant.
So there I am "helping" my SIL on a tree job by using the grapple to transport cut logs to and fro.
I notice that the BH is getting a little too close to this guys garage door, so I swing it 90 degrees to "make a little more room", but now it's sticking out to the side.
Well I promptly forgot about that, as I was focusing on grabbing logs.
So as I am exiting the back yard, I hear a "strange noise" and feel a "slight bump".
Well as it turns out, the bucket of the BH grabbed the fence gate and ripped it clean off......o_O
As soon as the last F-bomb rolled out of my mouth, there I was with my 40+ years of experience of "all things mechanical" and my emergency tool box, straightening the gate pins, and reattaching it.
As it turns out, the storm damage so severe, my "Water-gate cover up" was barely a "drop in the bucket".
I suppose they were focused on the giant tree sticking out of the house..... :ROFLMAO: :ROFLMAO: :ROFLMAO:
lynnmor
B2601-1
May 3, 2021
1,736
1,537
Red Lion
Yesterday I drove the tractor with backhoe in the walk to the front door and plucked out a dead bush. "Someone" parked her lawn tractor and wagon at the walk so on the way out I cut the corner to miss it and the tail swing of the hoe took the cast post lamp clean off. I needed more work.
Blue2Orange
Apr 3, 2025
339
234
Bayview Township
Some people think I'm warped or overcautious or .... I use wheel chucks on the tractor when parked in the garage. The incline on the slab is not noticeable until you wash the surface and see how it drains out the doors. Tested the BX. Shut down with bucket and dirt box off the slab. Disengaged the brake. It moved. Hit the brake and locked it. Still put the chucks in.
Regarding garage damage. Not the BX. My old NH. Tight exit so slow and steady when pulling out. But..... many years ago I turned a bit too soon. Bucket just nicked the trim. Enough to crack the wood trim. Definitely a stupid move. Could have, should have backed it up as normal. And look forward before swing around the tractor.
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
152
295
Mark Twain Forest
That is the only way to learn.
Now when using the loader, I always have a full 45 gal sprayer tank on the 3pt. When the L2501 feels like a rocker, I know I have hit the limit. And enable 4WD. Spun the back wheels in the highway drainage ditch last week because I did not want to make multiple trips. Had to make multiple trips. :mad:
