S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,688
4,397
PEI Canada
Moved a pile of gravel and spread it out in preparation for a 12x20 tarp shed.
Moved on to pruning trees. Some aren't a fan of tbe BTR but i find it very useful.
If i had another 15 acres I'd get a UTV.
Reactions: 8 users
7,309
With 4+ days of cold rain coming, I mowed the lawn.
A coworker gave me a pair of noise reduction headphones with radio when I retired last year. Used them first time today.
Pretty simple, which matches my tech capabilities….😉
Was listening to some of my favorite rock radio station, and audio quality is REALLY GOOD! 👍
Reactions: 9 users
Kennyd4110
Vendor Member
Sep 7, 2013
1,505
886
Westminster, MD
www.boltonhooks.com
By the way, I found out that blue Loctite and cheap Chinese USB ports don't play well together. 😂
Loctite attacks most plastics, I too learned the hard way many years ago on my model helicopter!
I'll definitely be ordering some flow restrictors from @Kennyd4110 to slow down the boom and head rotation functions on the flail. I'll have to figure out what I have in terms of fittings,
Most likely 1/2" BSPP, at the connection between the QD and the hose, I'll have more soon. Don't take that as gospel though!
As the great Ronald Reagan said..."Trust but Verify"
Kennyd4110
Vendor Member
Sep 7, 2013
1,505
886
Westminster, MD
www.boltonhooks.com
@Kennyd4110, it looks like my Del Morino flail uses 1/4"-18 NPSM fittings but I'm not seeing that option for flow restrictors on your website. The hoses are 1/4" too.
I'll take a look at the fittings on the cylinders, but does the 1/2" ORB/SAE restrictor thread into the Summit Hydraulics multiplier? If it does, I could add four or even six of those between the Summit Hydraulics multiplier and the AGP12F-08S 1/2" couplers.
BSPP.
British Standard Pipe Parallel.
As mentioned before, that s the connection between the fitting and the QD.
I would guess so. I don't follow or use product(s) form Summit.
11,753
I ordered four of the ORB/SAE Female to ORB/SAE Male .031" Flow Restrictor 08 (1/2") from your site this evening. Looking at the images on your website and the specs provided by Summit Hydraulics, I should be able to install the restrictors into the valve multiplier block and then screw in the AGP12F-08S quick connect couplers that Summit provides with their multiplier kits into the flow restrictors. The Summit couplers are 1/2" with 3/4″-16 male ORB thread.
I ran the flail a bit this afternoon, and have used it for three or more years, but there's some finesse required with the controls when I move the cutting head in and out or rotate it. Hopefully those restrictors will eliminate the need for finesse.
6,300
Busy day but not much seat time today. Tractor was wearing the grapple and chipper from the last job of tree trimming. Swapped the chipper for the winch and headed off to do some clearing.
An old, long dead pine fell across the sewer line / UTV path. Decomposed enough to have no limbs, no bark, not attached to the ground at all, and busted in a couple places when it hit the ground. Just needed to clear the path and clear the sewer right of way for mowing later this year when the ground is dry, still had to cut it in a couple places to move it, but it was exponentially faster and easier than moving manually. IMG_5134.jpeg
The part that was on the slope, I winched up to flatter ground. Steeper than it looks and we got 4” of rain just a few days ago so it’s still pretty soft. I’m aware that’s more of an angled pull than is ideal, but it’s quite a light pull. IMG_5137.jpeg
I guess I’m still a little kid in some ways. It was gratifying watching the logs roll down the hill steam rolling sweet gum saplings, gaining speed until crashing to a stop against the bigger trees at the edge of the right of way. IMG_5138.jpeg
A short ways off, there was a log from a wind felled maple I’d gotten up most of a while back. At the time, thought I probably had enough firewood logs stacked at the wood yard. After splitting and stacking decided a little more would be good. Hitched it up for the ride home. IMG_5139.jpeg
On the way to the sewer line, had to cross the cut across the tail race for the neighbor’s pond and also cross the creek. Every time it rains 4” in two days, the creek crossing either washes in more sand or washes out or some combination. This time it washed in on the south (home) side and washed out on the north (sewer line) side.
Didn’t look like it would be a problem, but was quite surprised to get stuck in the middle if the creek. As soon as the front wheels started up the slope coming out, the right rear spun about half a rotation and sunk about a foot. Right rear spinning in soup and left front spinning in the air. I stopped briefly and thought this would potentially be a real problem on the old 2WD non-loader tractor the L replaced. But so long as I don’t lose my head, I have a grapple that can push me out backward, a diff lock that will throw power to the left rear better than splitting the brakes and braking the right, and I happen to have a 11,000 lb winch with a bunch of rigging on the 3 point. Not sure exactly how this is going to go, but I know I ain’t going to be stuck long, Backed out to get a different angle, locked the diff, and slowly crawled up the north slope with no more spinning.
After the maple log was home, rode the UTV trails that were dry enough to not damage with the L. Found a couple small issues that were resolved by removing a handful of large fallen limbs and small trees via the grapple. Didn’t even have to get out of the seat.
Did use the winch to pull this sourwood out of the trail. This is a 365 day constant spring/mud hole. No problem driving the Mule through it. Too soft to walk through without getting stuck. The L is quite capable in soft stuff, but I ain’t dumb enough to drive it into that just to grapple out a little sourwood tree.
Changed into the boxblade and bucket to dress up the creek crossing and touch up a gravel trail section that was washing due to a clogged ditch. Was planning to take a couple pics of that, but wife called asking if I could meet her at home in 30 minutes just as I started the actual work. Told her yes, which gave me about 20 minutes to fix the crossing and trail with another 10 to put up the tractor in the shop and run home in the Mule. Made it with 5 minutes to spare.
Today was one of those days that showed the qualities I love about my little Kubota with its top, tilt, grapple, winch, etc. and at the same time low key don’t always like. What I did with it today, I previously would have had to wait until the ground was a good bit drier, there would have been much, much more manual work, and it would have taken a solid day. Took me two and a half hours including all the implement swapping and travel time, which was probably at least half of it. Sometimes I wish it took a little longer.
Reactions: 14 users
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
634
1,789
Vermont
youtube.com
Mowed the lawn today...43f and cloudy. Don't think I mowed that chilly before but it really needed to be mowed. Next several days will be a lot of rain. The grass was wet but not like soaked, still caused by zero turn to stall a few times and had to use a small shovel to remove the grass. Yeah it was a long day but I couldn't wait until its sunny and completely dry other wise the grass would have been several feet high! 🤣
I hate mowing wet grass but sometimes you just don't have a choice and take the opportunity of a day it doesn't rain and get it done.
Then to come inside and find out my washing machine was leaking quite a bit of water.
There's always something.
JonM
Nov 29, 2024
251
638
wisconsin
after 1.5 days of straight rain threw the horses out off the dry lot and into the fields using the tractor to pull in the dirty water troughs clean em and refill with the tote
Reactions: 12 users
7,309
JonM
Nov 29, 2024
251
638
wisconsin
Darn that looks soggy. Nice looking horses.
yeah super soggy
4 friesians
1 quarter horse
1 arabian
1 percheron/quarter horse
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
yeah super soggy
4 friesians
1 quarter horse
1 arabian
Dang. Send that rain down this way!
Super dry here, 1.3in for the month, much hotter and windy. I'm gonna move the cows over to the last pasture with forage today, I might get 10 days out of that 10 acre pasture. Spring/summer rains didn't hit here until last week of May last year. I'm really praying that the rain returns soon and often.
JonM
Nov 29, 2024
251
638
wisconsin
damn. good luck on getting some rain.
we turn our horses out for half days around noon till 5 or 6pm. rest of the time its the dry lot. but their lot is almost 3 acres so they have a LOT of room to run when not on pasture.
Blue2Orange
Apr 3, 2025
400
278
Bayview Township
Shorter than expected session of moving gravel using the FEL and Vassar dirt bucket to fill dips and rolls on the driveway. Discovered something interesting regarding the fuel gauge and why I should have stuck with my "do not run with less than 1/2 tank and refuel at 1/4 full or sooner". Fuel gauge idiot light flashed on while heading up hill. Light off when on more or less level ground. IIRC, ~1/8 of tank on the gauge sitting in the garage when shutting down for the day. Small tank on a BX. Did put unnecessary stress on the fuel pump?
PHPaul
Apr 2, 2015
1,261
1,564
Downeast Maine
www.eastovershoe.com
Spread with the bucket, graded with the box blade and rolled with my Redneck Roller 18 yards of asphalt millings on the remnants of a well worn gravel drive. (Picture is of a lawn patch I rolled as a test of the newly built roller)
T'was me, I'd want to add some sort of binder and hit it with a plate compactor, but the owner was happy and paid cash so...
Reactions: 7 users
JonM
Nov 29, 2024
251
638
wisconsin
that roller is genius!!
S-G-R
Jun 17, 2020
1,688
4,397
PEI Canada
Mowed grass. Looks like 5 days of rain coming so I figured I better get it done.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
458
533
NE Ohio
Mowed mine yesterday. Over an inch of rain overnight and more today...still coming. Supposed to rain daily for the next five days. It's coming your way!
biketopia
Feb 15, 2024
422
444
Warrenton VA
My back 2 acres hasn't been cut in over a month and it's damn near ready to be cut for hay. It's all I can do to keep the 3 acres that surround the house and barn cut back with all the rain we've had this spring, 6" this month so far.
I'm planning to pull the loader off this weekend and throw the 72" finish mower on to slowly tackle that. Although I could fire up the old JD 1530 with a 6ft brush hog the old homeowner left for us, hmmmm
6,873
Not sure where to post this...
Just a reminder to keep your head on a swivel and be mindful of everything and everyone around you.
Operator was cleaning up trees with an excavator. Evidently he made contact with someone's head while rotating the cab.
