checking the brake actuator on BX25
11,049
Sometimes reading a manual can have adverse effects!
Are you having brake drag?
RonaldS
Bx25
May 16, 2023
Washington
The pedal would not return after the parking brake was released. I cleaned out the linkage area and used a penetrating oil and things are much better but there is a small hesitation before the pedal returns.
11,049
Not right now, but would like to know how to check the actuator for uneven wear.
To do that would require you to remove the axle housing.
If you aren't having brake drag, don't worry about it.
