Diesel transfer tank
11,757
Old Machinist
May 27, 2024
723
841
NE FL
Been down this rabbit hole. Started with two 55 gallon steel drums that started to form surface rust inside. Switched to white plastic drums and had one crack on me. Fortunately it cracked above the fuel level. After that I found a 100 gallon aluminum tank off a Freighliner truck at the salvage yard. I think I paid $80 for it.
I have a $65 eBay 12V pump, hose, nozzle setup. Last year I bought a auto shutoff nozzle for another $30 and added a goldenrod filter. Plumbed it with PVC pipe.
I have a local delivery company fill it and still pay a little less than on road pump price.
Gaspasser
L6060, FEL, forks, BB, rake, snowblower, KX033 mini-ex, dump truck, splitters.
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Thanks for all the advice folks. Much appreciated. Been looking at the choices within reasonable distance of me on FB marketplace. Either rusting junk that leaks for cheap or good condition used at just a slight discount to buying new. Neighbor who is a landscaper recommends I get a new 100 gal tank with an electric pump and have the off road diesel delivered instead of schlepping the tank back and forth for refueling. The oil company is 2 miles away and the driver said his company is willing to do this. Have to call the office when they open in the morning to see what cost would be.
jyoutz
Jan 14, 2019
3,626
2,719
Edgewood, New Mexico
Thsnks for all the advice folks. Much appreciated. Been looking at the choices within reasonable distance of me on FB marketplace. Either rusting junk that leaks for cheap or good condition used at just a slight discount to buying new. Neighbor who is a landscaper recommends I get a new 100 gal tank with an electric pump and have the off road diesel delivered instead of schlepping the tank back and forth for refueling. The oil company is 2 miles away and the driver said his company is willing to do this. Have to call the office when they open in the morning to see what cost would be.
If you can get home delivery it’s a no brainer. In my area, they will only home deliver for 500+ gallons, so I’m looking at getting this and mounting to a pallet so I can load it in the truck. I’ll add a hand crank pump, particulate and water filter. I don’t want to fool around with another battery to run an electric pump, and a hand crank doesn’t take long to dispense 20+ gallons into the tractor.
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Thanks Jay. I thought about manual pump but wondered how I could crank with one arm and reach the equipment with the hose/ nozzle with the other. Probably doable with the tractor but would involve advanced acrobatics with the mini ex due to location of the filler tube. Also, renting a Cat D315 excavator in June to stump several acres and estimated daily fuel consumption is 20 gallons per Milton Cat dealer. Lastly, I have a diesel dump truck. If price is reasonable for regular non-off road diesel, might just go with that for all my equipment. I'll see what the supplier says tomorrow.
jyoutz
Jan 14, 2019
3,626
2,719
Old Machinist
May 27, 2024
723
841
NE FL
Make sure and get an auto shutoff nozzle. I upgraded mine last year and it is a game changer for filling hard to see fluid levels.
I see a few sets with 12V pumps that include the auto shutoff nozzle for 100 bucks on Amazon.
RBsingl
Jul 1, 2022
488
573
Central IL
My standby generator has an 80 gallon tank and I can get it topped off when the farm supplier is delivering diesel to the farms on either side of me. I use an electric pump with auto shutoff nozzle to feed the Kubota and Deere from that tank. I keep a biostat additive in the tank to help prevent algae growth and the pump also has a water separator filter in line with it.
Using the generator tank to feed the other equipment helps keep fresher fuel in it because I like to keep it fairly full in case there is a long power outage.
Rodger
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
So took delivery of 100 gallon Bilt Rite steel tank (Mexico, not China), 12 v pump, auto filler nozzle, hose. Welds actually look pretty decent. Now just have to get filter assembly and associated piping. See that some folks have no filter, others one, and some others 2 in series. I was looking at Goldenrod system with 10 micron filter and water " blocking". if the one filter does both, do I really need a second filter? 2nd filter would also be 10 microns. And which order to put filters in? Pictures to follow if this #%**%@# rain ever stops.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
437
332
NH
I think it stopped!!!
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Some tanks have better vent, vacuum/pressure relief valves that help prevent air exchange thus water accumulation. I’ve had the two filter system long ago. It does give you visual verification of water collected. Now I run with just one filter water sorbing and 10micron filter. Supposedly reduces flow when reaching capacity.
imarobot
Apr 18, 2025
437
332
NH
Sorry, but my paper is all wet :(
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Thanks. I've been looking at Goldenrod filter system with see-thru chamber. Specifies 10 microns and "watersorb blocker." Has drain port in bottom of chamber presumably to drain sediment or water. Sounds like your system. Given the relatively low volume use I am projecting, thinking one filter will suffice. I'll update with pics and more details when I get to that project step.
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Pouring rain here so good day to work on diesel tank. Assembled pump, filters, hose and auto nozzle. Next steps will be to build a sturdy pallet with a shed style roof to repel weather. Fuel supplier will do an "inspection" prior to filling.
Question. The nut and wing nut on the filter bottoms are to drain water/particles. Are these 2 types of nuts for redundancy and to ensure that they don't come loose or is there some special technique to draining these. Pics below. Thanks gang.
3,164
That looks like a typical petcock. The “wingnut” is all you need to turn and fluid will start coming out. They were used on radiators in the past. You may have one to drain the tank on your air compressor.
They are also called drain cocks.
The hex is what is used to turn the petcock into or out of the housing.
3,164
And that set up looks like a perfect mess making arrangement when you need to drain the water or sediment out of the filter. You may want to steal an old baking pan from your wife, buy some aluminum foil pans to discard, or get a form a funnel to drain into a bucket off to the side.
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Thanks Russell. Appreciated. I see your point. I can swing the array out over the side of the tank but I was concerned about hanging it out where it could be snagged or collided with. It was a bit tricky to get all joints aligned with proper tightness. Will do a leak test with minimal fuel.
3,164
I wouldn’t worry too much about it. If you’re getting good fuel hopefully there won’t be much water in it to drain out. It may take a few years between drainings if you get lucky!
If it does become too messy, too often then consider changing it somehow.
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Thanks. I have a short term project that will take about 200-300 gallons in June (rented a big excavator to do stumping). After that, I estimate about 100-150 gallons a year. So I won't be a big time user over time. I'm lucky to have a fuel company down the road that is willing to deliver small volumes.
