Just about ready to give her a workout!
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,195
3,501
My, what a big auger you have there! Bet you hear that a lot. 😉
That’s a lot of auger; you must not have large rocks in your soil or Virginia clay to deal with, good luck.👍
They are far away from VA clay. Might hit a few potatoes, though 😄
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
Auger is 24”, probably should have gotten a 18, but the ‘bota powered it just fine. Soil is sand, gravel, and tree roots.
SCP
Kubota M62 TLB, RCF2772, HR3584, SGC2072, SA20, PFL4648
Feb 15, 2025
23
47
Idaho
I pray you never get that sucker stuck (with no reverse option from your PTO drive), update with some hole progress.
#40Fan
475
330
Who else is picturing the tractor doing a wheelie because he didn't get the PTO shut off in time?
Reactions: 6 users
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
Poked all 4 corners yesterday , just went slow, engine at 1000 rpms, as I got deep, I’d stop PTO, pull auger up, and fling all the excess dirt off the blade. We had to stop and chop out a couple of big roots though. So far so good.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
Turns out an 18” is easier to control and takes a lot less concrete. This 3-point mixer is invaluable for setting pole-barn poles. One load of 8-10 bags sets one pole. Hydraulic top link makes dumping easy. Have to run the engine at idle to keep from spinning drum too fast though and rear remote pressure makes the controls pretty touchy.
Reactions: 7 users
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
This weeks progress, 18 poles set, 4 to go. 2-1/2 pallets of 80 lb bags. Good thing we had a couple 20 year olds working for us!! Frame out next week.
Reactions: 15 users
NorthwoodsLife
Oct 15, 2021
1,411
1,472
Wisconsin
Please continue and keep showing this projects progress. Love it.
And include the conehead pic taker. Lol
10,194
Are you doing a concrete floor?
If you are, might i suggest hydronic piping before the pour.
My house and garage is all hydronic heated and it's super cheap and super comfortable!
Free details for success if you want it.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
1500 sf of foam plus 1000+ feet of pex is anything but cheap . That plus a boiler would add over $10k to the build. So no, I’m not doing hydronic. I’m insulating and installing the wood stove I already have.
10,194
I did my entire house and garage for far less than that.
A really good boiler (on demand) is about 2K.
But hey I get it, you don't want the cost. ;)
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
How long ago did you build your house and garage? Material Prices and labor are pretty crazy these days😵💫
10,194
I started buying materials for my house back in 2010 and stock piled a lot of it.
But almost all of the electrical and plumbing I didn't do until 2020 as I wanted the most up to date Equipment I could get.
Yes parts are not cheap, but they are only slightly higher than the last build I did 2 years ago.
I also built a second copy of my house 2 years ago.
I buy everything from some great supply houses, that I don't pay anywhere near local costs for parts.
The pex is $233.59 for 1000ft you would need 2 rolls to do all of it perfectly.
$1475.00 in foam, yes that's the expensive part of it.
That's all you need to do now, you can do a boiler and all other parts later.
The boiler you would use is $1299.77 for 199,000 BTU.
You would be looking at about $600 in supporting parts.
I have three zones in my garage and it's 1080 SF, for 1500 SF you would want to do 4 zones.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
153
155
Northern Idaho
I might put down foam and plumb just to it’s there for later. Still need a trench and natural gas line.
