Bucket hooks
SilverEagle
L4400 HST1,
Aug 15, 2024
22
12
I have a L4400, 703 loader and 6’ bucket. Are there any good options for bucket hooks rather than welding?
thanks in advance,
john
8,557
Yep!
gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
May 5, 2010
234
Hooksett, NH
Just another option in case you haven't see it.
No drilling or welding and you can store them in your toolbox.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
36
Lakes Region, NH
Check out jufabworks.com. I have their workmaster plate which bolts onto the bucket and provides two chain hooks, a 2" receiver, and two "grab" handles and the plate serves to reinforce the top edge of the bucket.
8,557
While that looks Neeto, it's one use away from bending the snot out of the bucket.
Bmyers
May 27, 2019
3,420
4,219
Southern Illinois
I will toss my vote in for Ken's Bolt-on Hooks. Have had them on on my bucket for a few years now and they have worked great. Easy to install with a good drill and step bit. I think it took me longer to gather my stuff than it did to actually install the hooks.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,471
1,695
Near Lancaster, PA, USA
My BIL has Ken's bolt-on hooks. Unless you're a competent DIY'er, it the way to go. Very high quality.
StephenR
45
23
Kentucky
I bought 2 bolt on bucket hooks from Amazon that came with grade 8 bolts are very heavy hooks. They were $30 but much better than welding some on.
  • Dislike
Squirrely Baker
20
11
Idaho
I understood that you dont want to put too much pressure on the cylinders at their full extension. For lifting straight up, wouldnt this recommend putting the hooks on the back side of the bucket? Photos below explain my concern.
Not ideal
Better option for straight lifting
Is this something to consider or am I thinking too hard?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,544
2,008
Western MT
Center of the bucket. However, you might want to reinforce your bucket depending on what you plan to lift.
Kennyd4110
Vendor Member
Sep 7, 2013
1,346
654
Westminster, MD
www.boltonhooks.com
@Squirrely Baker
In the first pic (copied from our website I think), the cylinders are in tension, and no risk of bending. Lifting to the max capacity of the loader is no issue like this.
Cylinders (rods) bend when they are at full extension and they are forced to try to compress, like when backdragging with the edge of the bucket.
S-G-R
LX3310
Jun 17, 2020
1,251
2,794
PEI Canada
Another plug for Ken. Back when they were new and shiny.
Reactions: 6 users
Squirrely Baker
20
11
Idaho
@Squirrely Baker
In the first pic (copied from out website I think), the cylinders are in tension, and no risk of bending. Lifting to the max capacity of the loader is no issue like this.
Maybe I misunderstood the issue but I thought pulling the cylinders out all the way under a load would damage the seals. Not a bending concern, but putting to much pressure against the seals.
Yes both pics are from your site. Im trying to determine where to put the hooks. I anticipate having to pull straight up and was concerned that curling the bucket under, as in the first pic, would stress the cylinder seals too much under heavy weight.
Kennyd4110
Vendor Member
Sep 7, 2013
1,346
654
Westminster, MD
www.boltonhooks.com
The long and short of it is if you use the loader as intended and within capacity, there in NO issues.
People get in trouble when that start yanking and pulling hard with the loader, it's not meant for that. It's designed to LIFT and PUSH, other activities are trying to pull the loader off of the tractor.
Don't overthink it.
What tractor/loader/bucket do you have?
Squirrely Baker
20
11
Idaho
Don't overthink it.
Overthinking is how I ended up with a tractor ;)
LX2620 with a 535 loader and the 54" quick attach bucket.
