FAST B7100
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
275
232
Wahkiacus, Washington
Got it. The adjustment screw for steering play was WAY wrong. To get the play out took the screw way down below the locknut. This is why the unit was on Amazon for the cheap? So I'm inside the 30 days and it's going back.
Garbage and manure coming from Amazon, even from a seemingly good vendor. But they have to dump it somewhere?
10,642
It's sad that they can't make a simple part like a manual steering box.
Send a PM to @Mountainman and see if he has a good box for you.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
181
Attalla Alabama
mossycreekoutdoors.com
I do have a couple good steering boxes for b7100 gear drive.
It is unfortunate they cannot seem to get these aftermarket steering gearboxes right. There is a good market for them. But i get lots of people try them because they are cheaper than a used oem box only for them to come back and get a good used box.
JRHill
Apr 26, 2016
275
232
Each time I tried to write a negative review the Amazon website malfunctioned and deleted everything I tr
Thank you sir
Yes, @Mountainman , I will be in contact when I determine which way to proceed. I see that Kumar (who supplied this item) also has parts kits for rebuilding the original steering gear but you can imagine how much trust I have in them now. Especially when I haven't been successful by phone and their email is broken. I suppose its a good thing it was an Amazon purchase and not direct.
There is a Kubota dealer an hour away so I'm thinking about a visit to price out the OEM gears and seals. The shafts/bushings are seemingly in usable condition. Overall it's not a terrible thing as I don't often roll in 3rd gear at full throttle. I don't work that fast anymore ;)
But nice, tight steering is such a operational blessing. Ironically the rod ends and 'pitman' are reasonably good except the rubbers are checked. If I could be sure to source OEM replacements I'd just fix it. @North Idaho Wolfman : pretty please, could you zoom out on the exploded view in post #19 to include the stem and the part numbers?
Appreciate y'all. Next up: when to do the repair? The ol machine is just as important in the winter as the summer. There is no good downtime. The B7100 goes places and does things that Big Bertha can't get to or safely.
10,642
Most of the internal parts are obsolete from kubota, that's the reason the aftermarket game is so big.
You can see all the parts and numbers here:
If you can't find the right parts let me know and I'll point them out.
JRHill
Apr 26, 2016
275
232
#3, 66811-41200, Comp, Nut Ball;
#5, H6680-41150, Shaft, Sector
For #3, I need two each - one for the tractor and, according to the wife, my Nut Ball is missing so I need a replacement. All my parts are obsolete too.
10,642
Do you have your nitro pills in hand and 911 on speed dial and a really good life insurance policy?
OEM will kill you!! :eek:
JRHill
Apr 26, 2016
275
232
The problem is the backlash on the steering shaft, ball nut and bearings.
Many thanks to @Mountainman for hinting, ever so graciously, that I should look a bit further instead of just being a parts/assembly swapper. He sure could've sold me the steering box assy but offered some motivation beforehand.
I've had some really nasty customer service stuff lately and it is so refreshing to come across somebody like MM. I will be a customer of his at some point.
Mountainman
Jul 10, 2022
443
181
Attalla Alabama
I appreciate that. Its always my goal to help people fix their tractors primarily and sell parts secondary. What people do with my information is up to them. But anyway let me check i may very well have a good shaft ball nut assembly
Bluelick
B7100, MMM, pond scoop, carryall, boom pole
May 24, 2011
22
Berea, KY
Greetings,
Forgive me if I'm hijacking this thread and please let me know if I should start a new one instead. The steering went out on my old B7100 HST E yesterday and after checking the replacement cost (without having taken any medication) I've been looking around and found this thread. I have not yet pulled the box to see what's going on, but was leaning toward an aftermarket box. Sorry to see the bad experience with that by the OP. So, my questions: Is there a better aftermarket box? Or, Mountainman, do you have one that would fit and if so what's the cost? I know the HST box is different from the non-HST. Thanks for taking a minute to consider this.
Bluelick
JRHill
Apr 26, 2016
275
232
I simply would NOT buy an aftermarket steering gear.
How did the steering 'go out'? I've seen plenty of worn out/loose steering gears but never seen one break unless it was a power steering type.
Bluelick
May 24, 2011
22
Berea, KY
The steering was pretty loose when I got the tractor 15 years ago, and didn't ever seem to change, but yesterday it locked up and would only turn very slightly to the left or go straight. I was at the far end of the dam on my pond, facing the wrong way (of course) but by going back and forth I got aimed so I could traverse the dam in reverse and with a good bit of hinking and jinking got it back to where I park it next to my shop. At one point (right after I turned it off I think) the steering wheel would just spin, but then locked up again. So I don't know what's going on in there yet, but something ain't right!
JRHill
Apr 26, 2016
275
232
Nothing yet. I turned the steering off center to adjust it and was able to get a tiny bit more of the play removed. But I'm awaiting the off season to take the machine out of service. I'm not going to replace the steering gear now that I know where I can get parts once I identify the cause of the play. It's still drivable.
When the off season actually happens varies by the year though.
Bluelick
May 24, 2011
22
Berea, KY
Right, hard to say when the last mowing and the first snow will happen! Hopefully Mountainman will be along. Was the Kumar unit unusable or just had a lot more play than you were satisfied with? I assume you sent it back.
JRHill
Apr 26, 2016
275
232
After filling the Kumar unit with 90# it had a little bit of play with no Pitman shaft movement so I attempted to adjust it. The adjustments would not take up the play and movement should've stiffened up any rotation at the extreme - nope. So I drained it and returned it. They'll just sell it to someone else I'm sure.
Bluelick
May 24, 2011
22
Berea, KY
I understand that issues with aftermarket parts, but I am considering this one at $250 with free shipping and a one year warranty. If it works and gets me through this mowing season that would buy me time to consider a rebuild on the original box if I'm not satisfied with it.
That said, I'll go ahead and pull the original and have a look at what's going on, I have to do that regardless. And perhaps @Mountainman will have something too.
