Lifting Arms for the belly mower on my Kubota B2620 will not lower
cleverbear1
Kubota B2026
Apr 30, 2025
Saskatoon, Saskatchewan
I have a Kubota B2620. I also have a belly mower that I remove in the fall and reattach in the spring. This afternoon, I serviced the mower. I put a set of tripod coasters under each wheel of the mower to make it easier to move. Before moving the mower under the tractor, I raised the lifting arms with no problem. I put the mower under the tractor, attached the PTO and then tried to lower the lifting arms. They wouldn't budge. I removed the coasters and tried again and they still wouldn't lower. Has anyone have any suggestions on what could be going wrong?
RBsingl
Jul 1, 2022
485
566
Central IL
Check the lowering speed control knob to make sure that it wasn't accidentally moved to the lock position.
Rodger
SDT
multiple and various
Apr 15, 2018
3,423
1,199
SE, IN
Verify that the lifting mechanism is not latched in the Up position as one would customarily do after removing the MMM.
