10-30 0il question
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
239
260
Pennsylvania
can I use regular 10-30 oil in a B5100e or must it be diesel spec only?
7,347
Pretty sure you'd want to stick with a diesel-rated motor oil.
Beyond that, any flavor is your choice.
3,082
let see if we can clear up a bit of "oil" thoughts.
Diesels burn and thus give off a good amount of "soot" - the soots are simple carbon particles of not 100% burned fuel.
These particles can add up and actually become somewhat "large" in a microscopic level.
The diesel oil has additives that "capture" these particles ........... well, let say they make the particles NOT get together.... keeping them small and hopefully captured in the filter medium.
SO it is really a MUST to use diesel OIL in a diesel engine = you pick the brand and weight!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
I don't recall any recommendations for diesels that were not for diesel engine oil. Check the API ratings. Oil for gasoline engines starts with "S"" and diesel with a "C". Easy to remember by Spark vs Compression ignition.
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
When I first got my B7200 in the 1980's I used regular automotive oil for the first couple of oil changes as it was also good for "light diesel engines". Not sure if that is the case now or even if a Kubota engine could be called "light". Have consistently used proper diesel oil since then.
7,328
There are plenty of dual rated oils targeting over the road diesel engines in cars and light trucks.. API rules say the C rating should be listed first if the oil is formulated for diesel and also passes gasoline engine requirements. If the oil is formulated for gasoline engines but also passes diesel requirements the "S" category is listed first.
A B7200 probably does not care of its a "light duty" diesel oil.
Dam
chim
Jan 19, 2013
3,278
2,979
would be easier if 'G' meant gas, 'D' for diesel :)
have never seen a 'spark' engine run without compression:rolleyes:
If it were my system, I'd change it for you. But then someone would come along and want to change the "G" to "P" for Petrol? I suppose the key word is "ignition" :)
