Oil level inconsistant
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
153
23
SW Washington State.
The hyd oil level on my MX 4800 never seems to stay the same, it shows nothing, quarter or half, and over full. Never consistent, and it does not matter if the loader is up, down, or half way.
I worry about it being over filled, but when it does not show on the sight glass for a few hours I worry about it being low… so I add a quart or half a gallon, pretty soon it is showing half or over.
Any ideas? Thoughts? Suggestions?
Hugo Habicht
G1900
Jun 24, 2024
1,506
2,159
Ireland
Is the tractor perfectly level when you check the oil?
And I would think the level changes with oil temperature too.
captmikem
Mar 16, 2017
153
23
Yes, level. and it can be winter or summer, I would expect a slight change as the oil gets hot, but this is pretty radical.
JonM
Nov 29, 2024
237
598
wisconsin
hydrolix oil expanss a lot with heat
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
At refill measure the capacity that you put in per the specs, and don't sweat it.
Unless you have fluid leakage under the tractor...
Don't fix what isn't broken.
captmikem
Mar 16, 2017
153
23
That is my thought, there is never (well, occasionaaly a hose or fitting leak but usually just a drip that I fix quickly. But never any oil spots under the tractor when sitting and no oil trails when moving. Just hate to be under or over filled.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
278
227
Indiana
Wouldn't the fluid level in the reservoir depend on the position of any hydraulic implements that are hooked up, including the 3PH?
7,303
no, level stays the same with the 3p up or down, loader up or down, bucket rotated in or out.
Just guessing, but possibly due to the geometry of the vessel/sump the fluid is in, I can see small variations in temp, etc. could/would change what you see in the sight glass.
As an example, my little BX takes about 3 gallons. The difference between off the dipstick and full is only about a quart + - - maybe 1.5 quarts.
The dipstick is in a narrow part of the sump. Little bit of fluid changes the level on the stick quite a lot.
Those sight glasses are often a problem for many owners.
I prefer a dipstick.... ;)
Hugo Habicht
G1900
Jun 24, 2024
1,506
2,159
Ireland
Oil level does change with cylinder in or out. The rod displaces oil when in. But it may be too small to see.
In this case it is oil temperature. Thermal expansion of oil is way more than of the enclosure.
And position of the tractor has a huge impact. But you said it is perfectly level when you check it.
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
268
Poplarville, MS
I don't think it can be hurt by overfilling....in fact, think it could be running out the top and still not hurt anything....it's low you don't want !!!!!!!
11,679
There's an equation for the expansion of hydraulic oil as a function of the coefficient of thermal expansion and the temperature change.
Reservoir Volume = System Volume * (1 + (β * ΔT)) where β is the coefficient of thermal expansion, and ΔT is the change in temperature.
Who knows what β is for UDT or UDT2, but if it's .0007 which is a common value for engine oil, and ΔT is around 100°F, then the volume of the hydraulic oil could increase by 7%. The MX6000 (similar to MX4800) supposedly has 11.6 gallons (46.4 qt) of hydraulic oil so with 7% expansion that would be 49.6 qt or an increase of about 3.25 qt.
Kubota says nothing in the owner's manual about oil temperature when checking hydraulic oil, only to lower the implement to the ground (for safety I assume), to park the tractor on level ground, and to shut off the engine. So now I wonder if the difference for an MX as indicated by A below is around 3 Qts. That would make sense to me.
captmikem
Mar 16, 2017
153
23
I think you are correct, around 3 qtss. Pretty much the same for the MX. It does state not to start the engine if the oil is below the indicator, but I have that happen often. System holds 11.6 US gal. so it is a LOT of hyd fluid.
old and tired
1,919
1,297
This information is for my L2800 HST... so if your tractor is smaller or larger, amounts would be different!! Normal Fill capacity of my tractor is 7.5 gallons of hydraulic fluid, thanks to this forum when someone could not see that they overfilled hydraulic fluid until it was completely topped off... they measured 3 gallons that they removed until it was within the sight glass.
Likewise, I had the hydraulic oil cooler line come disconnected when I was chipping up some limbs... I was able to drive it back up to the house without any issues. I refilled it until the sight glass showed the correct level. Again it was 3 gallons that I had lost but was able to drive the tractor. I would not recommend cutting the grass with it 3 gallons low... it would over heat quickly!!!
So there is a large amount of space for hydraulic fluid and the space is so large to allow the oil to expand and "cool" somewhat...
Now for my tractor and why I run about 1.5 gallons overfilled all the time; there was a Product Improvement Bulletin from Kubota to address "ratching" noise from the overriding PTO CAMS. Bottom line, it said to overfill the hydraulic tank with 1.7 (might be 1.8 I don't have it handy right now) so that you submerge the PTO drive train in the oil so that the "noise" would be under the oil. There was also a change over from a sight glass to a dip stick (screwed into the same spot). But I did not get one, I just run extra fluid in mine.
Check the fluid in the morning, on a level ground.... then don't worry about it!!!
