Garage door height
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
My garage door opening is high enough for my new tractor but the door would need to open up higher.
I can push it higher, so I thought I could have someone stiffen up the spring so it pulls back more on it. But the contractor said he'd need to change the rails. Does that make sense? What is the right solution?
3,847
2,390
Do you have an electric operator on it? If so, you may be able to adjust it to open further.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
605
621
Lake Almanor, Ca
See if they have a 1 or 2’ extension for the type of opener shaft you have. I added a 2’ one to mine to get it completely opened…saved time and money redoing the tracks or getting a different opener. IMG_3837.jpeg
OntheRidge
Nov 1, 2020
495
588
Why not just fold your rops down?
11,035
Yes to do it properly you need rails that go higher if you have the room.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
452
707
NH
I always had to let the ROPS down until one day when it started raining and rushed into the garage. Yup, you guessed it. Sudden deceleration and an newly modified garage door trim style. Couldn't hide that one from the wife,
  • Sad
5,314
After smashing my door, and knocking it off the track for the 3rd time, I "adjusted" my door opener so that it opened another inch.
I'm not sure if thats "technically" the right thing to do, but it sure beats smashing the door. (y)
EDIT: Although I have a "side mounted' opener like this. Not a "railed" one.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
I have adjusted both styles (wall mount and belt drive) of door openers to make the bottom of the door even with the opening. As long as there is enough rail to accommodate the door.
One note about the ceiling hung opener- the bracket that attaches the trolley to the door hangs lower than the door. So if you go with an opener, get the wall mount.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
283
Bigfork Minnesota
The door on my garage has an opener on it , and I adjusted the opener to open just enough to clear the opening. On my shop door, I cut a slot in the horizontal track for the slide latch to hold the door open enough. So far I haven’t forgot to latch it when putting the tractor in the shop.
awesome
Sep 16, 2018
320
215
ottawa
I should have mentioned I don't have an opener.
I have a bit less than 24" available from the ceiling. So it does sound like I could get it extended higher.
So it means adding rail extensions and also moving the spring further up right?
So that would be about 2h job for a contractor?
5,187
Call an overhead garage door company, and get an estimate,....in CAD.
awesome
Sep 16, 2018
320
215
ottawa
My tractor shed has a manual overhead door. It was easy to adjust the spring just a little bit.
That's what I'm thinking. If I push on the door, I can see the cable being rolled up more on the pulley. So if I add more tension to the spring then it should work.
Or maybe I should just buy an opener and install it myself. I could adjust it to pull the door a bit more.
3,083
They will probably replace all the rails with slightly taller vertical sections and then the curved sections will be higher and the horizontal sections will be mounted higher also. (but maybe that was what was done for a whole new door that was closer to the ceiling in my case).
Here is a picture of what mine looks like
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
279
231
Indiana
That's what I'm thinking. If I push on the door, I can see the cable being rolled up more on the pulley. So if I add more tension to the spring then it should work....
Seems that way to me. Why did the 'contractor' think you need different rails?
I have heard those springs store a lot of energy, and if a guy isn't careful, he can get hurt pretty bad...
3,847
2,390
The surest way is to raise the rails, pulleys, etc.
The next surest is an operator, just be sure it won't hang down below the door. It shouldn't.
If you're sure it's still rolling on to the drums, you may be able to add a little tension. But, due to the geometry, there's a point where the cable actually starts unwinding a little as the door opens fully. When I adjusted my opener I think it's near the neutral point.
And caution, those springs store a lot of energy. You really need to have the right tools if you attempt it.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
It looks like you don't have a garage door opener installed to pull the door further open.
You could make a simple prop out of a 2x4. Set the top in place then slide the bottom over to push up on the door.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
53
316
53
MN
Try disconnecting the door from the opener and see if it opens far enough. The rails and the height of the ceiling or opener have little to do with the"travel" of the door. You need to adjust the travel opening, or get an extension kit for it to open further.
In my case I ended up removing the garage door opener, since I couldn't find an extension kit for my old model. My door is not heavy so, I lift it manually now.
Edit - sorry just read your other post about no opener. Still need to check what limits travel. You say you can lift it open far enough?
11,035
More spring tension will no do it, the spring tension is set for the door weight.
It needs longer rails and the spring moved up.
