Low cost rear ballast options
TRUCK3
59
10
Upstate NY
I need to come up with a low cost rear ballast option when using my FEL on my BX2680. I have been just leaving my box blade or even my tiller on the 3 pt. I'd rather have something taking up less space though, the box blade and tiller can get in the way in tight quarters.
Anything with weights seems to be an expensive option. I'm leaning toward picking up a used ballast box. The LP WB10 weighs 100 lbs itself - holds 4 cu ft. Crushed stone weighs about 100 lbs/cu ft, so that would max out a WB10 at 500 lbs. The BB1254 that I have weighs 325lbs which seems to work ok, so the ballast box at 400 lbs should be enough. The ballast box has it's weight some closer to the 3 pt, so I would need more than the 325 lbs to have the same effect.
My rear tires are filled, so I have that already.
Any other low cost option I'm missing?
6,285
carryall and a skid with a box on it,you fill with 'ballast'. I have 2 skids, light and heavy. light for mulch/compost loads, heavy for dirt/gravel/patio stones.
install carrayall then slide up light or heavy as required
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,938
2,337
Western MT
You can buy used ballast boxes for about $200 on Amazon. The advantage is how short they are for the potential weight added. Note: they may not be QH compatible. The carry alls are a bit wider, and you probably need to add a floor.
old and tired
1,919
1,297
I welded up a 3 point "carry all". Great project to learn to weld, used scrape angle iron... Did not plan on it (basically a "Happy Accident") that a 55 gallon drum was a great fit!!! I first started out making a carry-all but I wanted to be able to drop my tools off and be able to drive the tractor.
I needed a counter weight and since the 55 gallon drum fits, I filled it with old, dried bags of concrete (neighbor wanted them gone!) One strap later, it's good to go!!! The drum now had the PVC pipes removed, filled the rest of the space to the top with rocks, and used a manhole cover on the very top (also prefect fit!!) No photo of the final drum :( may be one day.
TRUCK3
59
10
Upstate NY
Thanks, didn't think of a carry-all; if I can keep it compact, might be better than a ballast box since I could get more uses out of it
old and tired
1,919
1,297
....might be better than a ballast box since I could get more uses out of it.
Like a sprayer? I mounted this sprayer to be in sections onto the carryall frame. It takes a little longer to assemble but it disassembles for easy cleaning and storage!!!
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
110
47
Fort Calhoun, NE, USA
I use a carry all. Built up the sides and back of a pallet. Stacked concrete blocks and assorted rocks, old brake rotors, etc.
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
103
133
Lakes Region NH and Sonoran Desert AZ
I bought a rear lift frame and cast a 300 pound concrete weight. It’s reversable so I can attach a ripper tooth into the 2” receiver. Total cost was $60 with sackrete and the receiver from Temu. IMG_1733.jpeg
Wooddog63
In the plan- MX 6000
Mar 31, 2025
23
23
NJ - NY adirondacks
I bought a rear lift frame and cast a 300 pound concrete weight. It’s reversable so I can attach a ripper tooth into the 2” receiver. Total cost was $60 with sackrete and the receiver from Temu. View attachment 152063
That’s awesome- and great weight for the ripper like you mentioned. I saw at a place I snowmobiled in Maine a guy took the barrel route and added U bolts drilled into the sides and embedded the long threads into the placed concrete. This was to hold shovels and rakes and chainsaw saber. The bottom he bolted a quartered tire cut in half for the handle ends to sit in. Some times what one thinks is cheap and ugly is innovative and serves the purpose
5,310
I am always impressed with the ingenuity y'all have when there is a post about ballast boxes.
It makes me ashamed that I bought one.
But here are some other things you can add to it when you settle on a design.
I'm especially proud of the vise,....too bad I have never actually needed it in the field....only in the pole barn.
TRUCK3
59
10
Upstate NY
Nice idea, I was thinking about something like this - I have a 3 pt receiver and initially was thinking welding a used weight frame to it. Costs of weights eliminated that. I was thinking about casting it in concrete - 2 cu ft. would give you about 300 lbs which seems about what this is.
Great ideas - and cheap!
Wooddog63
Mar 31, 2025
23
23
NJ - NY adirondacks
That’s awesome as well! Never say never on the vice- even to lock the chainsaw in to tune up the teeth
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Barrel, drawbar (runs through), concrete, PVC verticals with a larger horizontal header for cleanout and a milk crate for parts 'n pieces.
Tim Horton
296
70
Lake Superior
I contemplated several options for rear ballast and had several drawings of homemade options in my ...good ideas... notebook... Would not spend the money for a store bought and didn't get around to a DIY project..
I usually had the snowblower on the 3 point or used my 5' box blade for ballast that I could hang 4-6 suit case weights of 42lb each on. Worked well enough..
My 5 cents of experience..
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
449
706
NH
Hey Runs. The vise is a great idea. I'd use it to sharpen saw chains in the field.
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
North Branch, Minnesota
I scrounged around and found enough junk to make this. No dollars spent!!!
Well, the lower pins were purchased new at some point, found them in my spare parts bin.
Weighs 400# and fits close to the rear of the machine. It's enough to keep the backend from feeling light when the bucket is full of sand, so mission accomplished.
Plus I can easily add, or subtract, weight at any point!
chim
Jan 19, 2013
3,278
2,976
And a reflector band at the bottom, another great recommendation
With the strobes going, the triangle doesn't count for much:)
Here's a short of the previous Kubota. The current one is similar, but no wig-wag on it. Something like 7 different flash pattern for the strobes. Yep, growing up isn't my strong suit.
