Hydraulic Thumb on BH77
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
I've seen a few post where people talk about how to rig this up. I think I get the idea, but I'd like it if someone could confirm that this design is safe:
Edit: I mean "bote", not "stroke"
2" bore is ok? I should I go 3"
I understand the 2 pressure reliefs are required to avoid building too much pressure on the thumb. Is this what people are talking about?
A foot pedal would be better, but I already have an unused valve that I can repurpose for this.
Of course, I will also need to think about how to do proper routing to make sure I don't get a mess of hoses that can be ripped out.
Anything obvious I should be aware of?
Thanks for the help.
7,249
2" stroke is ok? I should I go 3"
A BH77 hoe does not have a power beyond port. It has two connections to the tractor - pressure in and tank return.
The port reliefs typically have 3 ports and simply go in line with the cylinder - no need for tees and additional hoses.
3,854
2,392
Looks good, but I doubt 2", or even 3", stroke will be sufficient. Do you have the thumb and mounting point mounted?
Edit: I thought the 77 had a T connection. If not, your new valve needs to go before the backhoe valve.
7,249
The BH77 has pressure in and tank return, This plumbing is similar to a loader third function. It will work on both a BH77 and BH70 and is much simpler than trying to use a valve with power beyond, You can gang the pressure reliefs together with a tee and mount it on the frame of the hoe. The electric valve also allows you to put a switch on one of the BH joysticks so you can operate the thumb without taking your hands off the joysticks.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
The M59 foot pedal never felt right. Added cleats that helped. Also added hand control rod that helped with delicate handing like stacking rocks. Hand control is more intuitive to me but probably a personal preference. Mention as hand control might be easier to fab
Funny the B26 thumb pedal though very similar is more ergonomic OEM design.
Once you experience a thumb, you’ll wonder how you did without.
OntheRidge
Nov 1, 2020
495
588
Just as a reference, the stroke on my thumb ram is 17". Bigger bh, yes.
awesome
Sep 16, 2018
320
215
ottawa
Sorry, I meant Bore, and not Stroke.
5,187
Same is true for a ZT mower!
awesome
Sep 16, 2018
320
215
ottawa
Isnt this a PB port that goes from the solenoid valve to the bh77 valve?
Also, no tank return on the solenoid valve?
7,249
The solenoid valve has a pressure IN and a tank OUT. The tank port is rated for 3000 PSI so it can be safely used to supply full system pressure to a downstream valve. Technically its not a power beyond port which in an open center system separates the outflow into independent high (neutral) pressure and low (tank) pressure circuits. Thats more than just semantics. There are functional differences in the way return oil from the cylinders is routed. In this case it puts the thumb cylinder in series with the inlet port on the BH valve. A typical PB valve puts it in parallel. Its a geeky distinction but important to understand.
awesome
Sep 16, 2018
320
215
ottawa
I think I understand.
But I will want to use my manual control valve since I already have one. In this case, I will need the PB on the valve right? I don't see how it would work otherwise.
So while I am not touching the valve, pressure will be maintained on both sides of the cylinder. But the relief valves would be triggered if I curl against the thumb.
7,249
If your valve is a typical monoblock you will need to plumb both power beyond and tank returm circuits.
The port reliefs will operste any time pressure in the work circuit exceeds the pressure setting . Typically the rod end relief is set higher than the base end and both are higher than the main system pressure.
awesome
Sep 16, 2018
320
215
ottawa
My valve is a monoblock, BM40.
I tried plumbing my valve yesterday. I took the backhoe off and plumbed the valve's T and P ports to the blue and red ports on the tractor and tried to activate a top-link cylinder. It did not work and my loader would not work either.
I left the PB sleeve into the N port of the valve and I put a plug on it. I'm thinking this is where I got it wrong. I should probably remove the sleeve and simply put a plug directly. By removing the sleeve, I believe the N and T port are effectively the same.
But that sounds like a dangerous experiment if I don't know what I'm doing, so I would appreciate some feedback before I try this.
awesome
Sep 16, 2018
320
215
ottawa
I don't think my idea about removing the sleeve would work. Because then the tank would be pressurized so both ends of the cylinder would get pressurized at the same time. So I think I need to plumb the P and N (with PB sleeve) to the tractor, and then add a 3rd hose from the T port and tee it on the loader's tank port.
This is without the backhoe attached
7,249
Yes, dangerous and incorrect analysis in your previpus post. You have to use the N port with the sleeve as ypu describe above.
awesome
Sep 16, 2018
320
215
ottawa
Thank you Dan. You're a very valuable member on these forums.
awesome
Sep 16, 2018
320
215
ottawa
Sorry, I mixed up 2 questions in the same thread.
The original post is about adding a valve on the backhoe to control a thumb. I would plumb this all on the BH77 without touching the tractor.
In the meantime, I went ahead and also plumbed my rear remote (A vevor valve that I mentioned in another thread a few years ago) but it didn't work. So since you mentioned something about the BH having only 2 onnections, I came back to this thread to follow up on this.
But to be clear: I have no intention on ever connecting the BH and the monoblock at the same time. It will always be one or the other. But it seems that if I plumb everything as per post #15, then I would be able to also connect the BH after the valve.
7,249
That clears up my confusion.
Kubota OEM plumbing would feed the aux valve with the loader PB (currenrly feeding the BH77) and use the aux PB to feed the BH77. That eloiminates the need to connect and reconbect the aux vakve and the BH77 connects just as it does now.
