Alternative Replacement Part for Joint Assembly
GermanPointer
Bx2360
Apr 2, 2025
Pittsburgh
Has anyone else needed to replace the universal joint assembly shaft that goes from the tractor to mower deck. Buying it from Kubota runs up over $700. Part number is #k5384-32032.
9,623
Do you need the whole shaft?
If you do, then No there is no good alternative source.
If you only need the joint just buy the joint.
loves2cycle73
BX2380
Apr 14, 2025
KY
I was looking for the same info. My tractor sat outside over the Winter and not the shaft is seized up. I have tried a ton of PB blaster, heat, etc. I cannot get them to come apart.
Workerbee
Zd21
Mar 1, 2020
322
189
MN
Tie one end to a big tree and the other end to your pickup. Sometimes thats the only way to get a stuck shaft apart if you dont have access to a machine shop.
