HYDRO FLUID
dmoore
2006 B7800, RC72-BA 72" mid mount mower, RB 1672 72" rear blade
Feb 8, 2010
84
9
Exmore,Virginia
So what do you guy's use as an alternative to Kubota's UDT fluid and can you mix it with another brand?
7,181
Are we talking about the B7800 in your profile or something else?
If it's your B7800, it's likely an HST?
If an HST, I wouldn't deviate from UDT.
I would actually upgrade to SUDT2.
5,187
Why not just drain, and change to SUDT2?
6,397
If you are actually talking about UDT and not SUDT2 most premium universal tractor transmission oils are "equivalent". And yes you can mix those products.
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
260
143
Agua Dulce, California
OK let me have it BUT I am using travelers tractor supply premium universal fluid in my B7800.
rh74
LX4020, LA545, LX2980, RB1672, BB2560, PFL1242
Feb 17, 2024
62
70
NY
The base oil in the Kubota udt2 and the aftermarket brands are the same. This is true for all oils (engine, hydro, gear, .etc) However the additives are not and the additives are what really matter in performance and reduced component wear. The aftermarket oil will most likely work, but at what cost. When it comes to hydro fluid it's best to use what the OEM recommends.
I'm all about saving money, but a hydro system is not one of those places.
10,085
There is both sides of the coin, some say they love, it others not so much.
I've heard more bad than good.
