B8200 HST Incline stalling
Snider
B8200 HST
Mar 8, 2025
California
I have a B8200 HST that appears to have hydro problems. The tractor will move in low range both forward and reverse, but . when in high range & you attempr to speed up or go up an incline, it stops.
is there a service video or manual on line I can follow on servicing the hydr system?
I just bought the tractor & I hope I haven’t gotten taken.
11,149
The HST is a completely separate Hydraulic pressure system than Loader and three point.
They are completely different pumps.
You could have a bad Mechanical clutch, that will cause it to loose power to the HST Pump.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
182
Attalla Alabama
mossycreekoutdoors.com
If you can put a tiller or cutter on it and put it under load see if it works normal or if it stalls out. That'll help determine whether its the clutch or hydrostat issue
11,149
This in itself is not that unusual and not necessarily an issue.
Could still be a mechanical clutch issue.
Very unlikely a HST issue, as that would present in low and in high.
One other option is your are pushing it too hard, try doing it again this time when it slows down, ease off the HST pedal and see if speed increases, you would be surprised how many times this advice works.
5,474
How steep of an incline?
And are you pulling anything?
The reason I ask, is that recently I was making a "sledding hill" for my grandkids and I wanted to get it a little higher; So I began climbing the 'hill" (small bump really) with a full bucket of snow and I stalled it.
Too steep of an incline combined with a full bucket = Fail.
Just an observation.
Snider
B8200 HST
Mar 8, 2025
California
Tried yesterday and it would not climb a low incline in forward or reverse.
since is new to me , where are the strainer screens located? I will be draining hyd fluids as well. Where are the drain plugs located. Yeah don’t know anything about the HST. Aany help here is welcomed. Also, like what lever does what?
5,188
Me thinks a workshop manual is in your near future!
Snider
B8200 HST
Mar 8, 2025
California
I bought a manual, but could not find a service manual.
This again is a HST 8200. On level ground it
Operates fine. With nothing in bucket or nothing attached behind, any slope it starts then stops & it sounds like pump starving for oil. Level is full.
Any ideas out there folks.
11,149
I sent you the WSM, look top right at the envelope.
Like I said before it could be the mechanical clutch causing your issues.
You need to see if when you try and move it uphill in high range if the propeller shaft is spinning at full speed, or if it's either slowing down or stopping.
You can get the same results if you set the parking brake well and put it in high range and try and move it.
You can pull the covers to look down on the shaft while operating it.
5,255
1,058
I do not know the configuration of a B820.
The symptom of stalling on slopes with other models is often traced to a failed mechanical lift pump.
Snider
B8200 HST
Mar 8, 2025
California
I'll have to pull plate as no one here to help. Thank you friend.
