Tire foaming question(s)....Has anyone here done it?
4,681
I am considering doing this to a problematic tire on my Yamaha Rhino.
But I was wondering if I do it, can that tire ever be replaced if it wears out?
I have also read about getting a "flat spot" if it sits too long. Is this true?
2,615
I have no idea about the foam but would suggest you try a product like FLATOUT or similar. They make some kind that is better for higher speed tires.
3,381
I bet it would be way stiffer than the other tires & ride like a rock.
drygulch
L3901, LA525, ever changing attachments
May 30, 2024
195
247
Alabama Foothills
www.ebay.com
Agree with this.
I had an ongoing issue on with a couple tires on an older ATV. Plugged multiple holes, used bead sealer, but kept leaking down.
Turned out to be a whole bunch of micro holes. Not sure how that happens
A variety of YouTube product comparisons and other research led me to Flatout off-road version, which solved my problem.
FWIW
Greg
4,681
I have put a tube in the other tire and it has held, but I was considering foaming them all just to prevent future flats.
After some poking around, it seems like there are no good DIY ways to do it.
I actually have a tube sitting on the shelf, but I was kicking around the idea to foam it, just to make it "totally leak proof forever".
I had some of that "Kubota brand" leak stopper left over when I did my front tires and I put it in one tire......But I'll be damned, I forgot which one I did it too. :D
LOL, the person that puts the most miles on it, is 6 years old and probably wouldn't care, since he has not even figured out that there is a "High and Low "gear yet.
3,986
2,683
Once you foam the tire you have to cut the tire off the wheel in the future when you need to change tires.
You will enjoy many hours trying to cut foam away from the wheels.
I wouldn't foam my aluminum wheels.
John T
2017 BX23S
May 5, 2017
1,188
735
under a rock
Doesn't foam add a substantial weight to the wheel?
I have a 10x16.5 skid steer tire filled and it weighs a ton... compared to the others...
different grades of foam??
John T
2017 BX23S
May 5, 2017
1,188
735
under a rock
personally I'd tube it.
I'm not a fan of slime or any other foaming Goo .... to me, It's a half azz remedy.
IF your stuck on the side of the road and you are a helpless old lady.... well yeah maybe.
but eventually the tire has to come off the rim and the tire guy will hate you. and probably charge double. some places won't touch it.
foam? I'm sure it's a good solution for maybe a skid steer when you want to get your moneys worth out of bald tires..... but after they are gone... It's probably best to just buy new rims AND tires. foam is a biotch to remove.
another aspect of foam is the ride quality. It has no 'give' or very little.
It's gonna be a Flintsones mobile.....
Dustball
2016 B2650HSDC
Sep 15, 2023
484
352
Hudson, WI
The other thread about using foam for setting fence posts had me thinking- how would the fence post foam do as tire foam?
I know regular spray foam is a no-go, breaks down too easily.
drygulch
May 30, 2024
195
247
Alabama Foothills
www.ebay.com
This helpless old lady came to believe that FlatOut can just be sprayed out with water. (Or reused apparently.) I'd heard the horror stories and didn't want a bunch of nasty goo in the tires.
And I figure if the tires only ever see dirt, they likely won't need replacing anyway, assuming (ass-you-me?) that FlatOut protects against additional leaks/punctures.🤞
Greg 👵
3,345
I foam filled the front tires on my B2910 22 years ago, and the four tires on my BX maybe 18 years ago.
At the time I asked the question about replacing tires in the future. The answer I got was we just cut the old tire off and install a new tire. Did not sound like a big deal to them...more than this I don't know.
I would myself foam both tires on the same axle though...
4,681
Out of mostly curiosity, I will call around and see how much it is.
In the mean time, I will just keep the compressor handy, until it gets warmer out, then install the tube.
Riding a Relic
Kubota 2201
Mar 4, 2025
Jackson's Gap, Alabama 36861
Co
I used to work for a garbage company, we had equipment done with foam filled tires. You can run the tire till the tread is flopping on it, and it will still hold the equipment up. For a 4 wheeler, probably not a good option.
Scm
BX23S
Sep 28, 2024
226
197
Missouri
I'm picking mine up in the next couple hours. I was quoted $86 for a 18x8.50x10
4,681
Thanks for that info.
Please report back when you have had time to "evaluate" your decision.
Also, what are you putting them on?
Scm
BX23S
Sep 28, 2024
226
197
Missouri
Front tires on my BX23s. Very happy I did it considering I blew two ($138ea) tires in a week with big holes in the sidewalls. I can now run them bald till I hit the foam, about a year here. I was kinda surprised at how heavy the tire were when done. From 20# to 60# ish each
