G1800 Should I buy?
Hugo Habicht
G1900
Jun 24, 2024
894
1,264
Ireland
Hi,
as far as I remember out of my head the G1800 front wheel rims are symmetrical and they have ball bearings both sides, 25mm inside diameter if I am not wrong.
Kind regards,
Hugo
p.s.: my left front wheel is leaking. Maybe we can swap one wheel, at least we have symmetrical front axles then again :ROFLMAO:
I had my tyre off already (what a job) and it is rim corrosion in my case. No point filling gunk in, corrosion removal and respraying has to be addressed at some stage and I don't want it to be messier than it is already. This is further down on my loooonnnng to do list :)
Hugo Habicht
G1900
Jun 24, 2024
894
1,264
Ireland
Is the grass catcher attached to the three point hitch? Was that always done like this?
Chairwolf
Kubota G1800
Jan 19, 2025
17
Roanoke, VA
Hi,
Kind regards,
Hugo
I checked mine, and it's just dry rotted. The whole sidewall is leaking, so I ordered 2 new front tires (4-ply) and a set of tire spoons. I did get the rubber off the rim with flat screw drivers, but it was no fun! Rim is in good shape. I may go around the edge of the rim with a file and sand paper just to make sure there are no burrs before I install the new tire.
Hugo Habicht
G1900
Jun 24, 2024
894
1,264
Ireland
My, your rims look like an order of magnitude better than mine, mine are leaking at the rim... I also had a bit of fun getting the tyre off the rim despite having proper tyre levers. My tyre mounting machine does not handle 8" rims. But I think I will make adapters, I do not want to do that job by hand again.
Chairwolf
Kubota G1800
Jan 19, 2025
17
Roanoke, VA
I was able to get the tires off with 2 flat screwdrivers and a flat bar. I did order a set of tire spoons to use for the rest (dismounting the other tire and mounting the 2 new ones). After doing it once, I think it will be easier with the right tools.
9,330
Since the 3-point hitch is nearly impossible to find, has anyone put a sleeve hitch on a G1800? Something like this?
Anything is possible with a hammer and heat!
Hugo Habicht
G1900
Jun 24, 2024
894
1,264
Ireland
I used Rustoleum gloss, and the color is Almond.
My wheels and other parts of the tractor were very close to RAL1015, light ivory but all pictures I found including the ones in the catalogue show a much lighter colour like the one you used. I mixed RAL9016 traffic white and RAL1015 light ivory now 50/50 and that should be close enough.
Working on straightening the rims and rust removal at the moment, turns out that the second rim that was not leaking had a lot more rust than the leaking one. They had put a tube in :oops:
Made adapters for the tyre mounting machine, getting the tyre on and off is a doodle now compared to the endless struggle before with the tyre levers.
Chairwolf
Kubota G1800
Jan 19, 2025
17
Roanoke, VA
Wow! Nice tyre machine! Now it's time for a visit with Mister Wirewheel. The Rustoleum paint looks like an exact match, or close enough for a garden tractor. Is it available where you are?
Hugo Habicht
G1900
Jun 24, 2024
894
1,264
Ireland
Hi,
yes, I've seen that paint around somewhere. But I use industrial two pack paint and I have it bought already
