Chains for winter plowing- 6060
ReGUN
l6060
Feb 28, 2025
Ontario Canada
Hey everyone, I’m new to this site. I just purchased a 6060 i live up north we have lots of snow here I wanna buy some chains to put on the 6060. I’m assuming you can only put them on the rear and NOT the front, what type of chains do you recommend?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,754
2,198
Western MT
Tirechain.com and some have bought them on Amazon from the same company for less.
I just use ladder chains. Eurostyle chains are better, but a lot more money. I also use tighteners.
I usually use on rear only, but to really steer the front, fronts are helpful.
WI_Hedgehog
Apr 24, 2024
1,035
1,447
Milwaukee, Wisconsin, U.S.A.
I have Euro front and back, for my situation they work incredibly well compared to ladder, BUT I'm guessing most people are facing something different so have different needs. Are you plowing or blowing, how much area how often and what's the surface material and drainage like?
Moose7060
Oct 14, 2023
827
2,243
bc
Trygg fast trac. Will last forever. Not cheap but the best. Have had a few sets on different tractors. I only use them on the rear.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I run trygg's on all four, would not want any thing different. When it comes to 2 vs 4 chains, you need to remember that installing chains makes the circumference of the wheel bigger, so you need to do both axles, so the ratio's stay close. I have had no issues with binding running front and rear chains.
Jsjac
B2650
Feb 13, 2022
228
349
I got a very good price on chains from the Kubota dealer. They beat tire chains.com by a lot.
9,896
Chains on all 4 is fine.
Just make sure they fit tight.
What tires do you have on the tractor, as that affects what chain style you should use.
ReGUN
l6060
Feb 28, 2025
Ontario Canada
Ill have to check the size of tires, i just purchased 2 weeks ago and the tractor is parked out at camp. Ill be heading out tomorrow, thank you everyone for replying, i can tell this will be an interesting and insightful forum to obtain info! ReGun
3,324
I think the Wolfman meant type of tire not size of tire. For example, with my R4 tires, ladder chains fell mostly between the lugs and were not that great, but better than nothing...
ReGUN
l6060
Feb 28, 2025
Ontario Canada
I never thought about that… good point! I’m running Nokia tires and they have a deep thread as you probably know. so yes, I wanna make sure no matter what chains I purchase, they don’t fall in between the lugs too much.. Ill check out the Tryggs and see what the Kubota dealer has and will be looking for next year now as snow season is coming to an end but i have some great options thanks to everyone who has replied to this thread! Thank you all!
JonM
Nov 29, 2024
163
342
wisconsin
ive got r14 tires on my 6060 did not feel the need for chains this past winter in wisconsin
ReGUN
l6060
Feb 28, 2025
Ontario Canada
Thank you for replying, good to know. I am running Nokia tires and they spin on the icy hills and if i am pushing snow at the same time ( with icy bottom) i get stuck. so, i definitely need the chains. I have a couple options for next season thanks to all who replied, much appreciated
