Full Synthetic Oil without CJ-4 Rating Okay?
slice38
M5-111
Jan 9, 2023
Waverly, Alabama
My manual says use oil with CJ-4 rating. This will be my first oil change. Shell makes a great 15w-40 full synthetic oil but it says something like " Improved wear performance versus API CJ-4 technology" indicating that it does not have the CJ-4 rating. Would it still be okay in your opinion even though it does not have the CJ-4 rating?
5,726
you should have posted the Shell product 'number' ! so 'we' could lookup and compare.....'apples to apples'.
I can't say 'yes, go ahead' just based on 'improved wear performance' as there may be other factors to compare.
5,395
Yes. Current service category is CK-4.
8,811
Does it have the newer CK-4 rating (2017) which exceeds the CJ-4 rating (2006)? Shell offers a bunch of oils with the CJ-4 rating and some with the CK-4 rating.
8,841
Yes it's a better (newer) rating than CJ-4.
5,726
If your engine was designed to run with CJ-4 oil in it, so you can use anything NEWER (CK-4,Cl-4,CZ-4...) and it'll be fine.
Now it 'might' run 'better', but it'll cost you more as synthetic oils cost more.....
I've got 1500hrs on the 'cheap stuff' ,zero issues,starts and runs same as it has from day one.
8,811
Did the OP ask for an opinion on the use of synthetic vs non-synthetic oil?
The Shell T6 oil is very affordable compared to the Schaeffer oil that I've been buying for the past five years or more. $70 for a 3-gallon pack ... that's pretty darn good.
jyoutz
Jan 14, 2019
3,393
2,441
Edgewood, New Mexico
Rotella T-6 is very good oil and I’ve been using it for years. I recently switched to Valvoline extreme synthetic diesel oil because Cummins endorses it for my truck. Since I buy it for the truck, I also use it in the tractor.
5,726
re: Did the OP ask for an opinion on the use of synthetic vs non-synthetic oil?
yes he did..... in that'CJ-4' is non-synthetic and the Rotella T6 is a full synthetic.
8,811
What are you talking about? CJ-4 vs. CK-4 relates to oil standards for use in diesel engines and has no bearing on whether the oil is synthetic, a blend or non-synthetic.
The OP isn't asking whether or not he should use synthetic oil, just confirming that the oil he wants to use meets the minimum requirement as provided in the owner's manual.
@slice38, as I and others have stated, your oil of choice is good to go since it exceeds the requirements listed in the owner's manual.
From the API.
slice38
M5-111
Jan 9, 2023
Waverly, Alabama
Wow! Thank you all for your detailed responses. This is a great forum. I’m going to get the Rotella T6 full synthetic 15W-40 and a Kubota filter. I’m comfortable now that it’s a suitable choice. Thanks again!
Big Mike
lmichael
Kubota G2160
Apr 23, 2021
726
347
Rockford IL area
Big Mike
You can always go higher in the ratings (unless there is some disclaimer on the product warning you not to do so). An example. GM began using a newer spec ATF (transmission fluid) from it's older Dexron series (III, IIIH, and IV) and began to spec Dexron VI and marketed it as "backward compatible" with some "caveats" for certain GM transmissions to stay with the older spec fluids.
I don't know of anything like that currently on your engine oil question, but for the most part you can always move "upscale", but never use anything "below" the spec called for in your manual
8,811
Big Mike
If you really want to say thanks, share a photo or two of your M5-111. That's a dream tractor for many here .... me included!! 😂
slice38
M5-111
Jan 9, 2023
Waverly, Alabama
Now that would be my pleasure!
8,811
What an awesome tractor! (y) I hope we get to see more of it in action. Thanks for sharing.
