Rear remotes leaking
JasonW
799
554
Al
You are not understanding this has nothing to do with the implement side.
The female couplers have a male thread that screws into the female port on the valve.
What I was describing was buying a coupler with female thraad and using a male to male adapter to convert it to male.
Okay I’m following you now
7,210
you can buy replacement coupler, the price is about 5-10 USD, but the shipping free and tax would be different. My quick connect fitting is ISO B 1/4, I only buy a female coupler $6, then the shipping fee $11. ISO A cheaper than ISO B.
The couplers used on the M series are nothing like the ones you are fsmiliar with and close to $100 each.
JasonW
799
554
Al
From what I found for my model the thread is 3/8 BSPP. Through the dealer they are a little over $100. I received the seal kits from the dealer yesterday. Should work on them in the next few days.
7,210
The cheapest price I have found for tgose couplers is Valpariso @ $75 each
11,758
@JasonW , would you mind taking some photos and posting here to show the process? I can't find a schematic showing the internals of these Faster couplers. Also, what seal kit did you get from the dealer?
Thanks! :)
JasonW
799
554
Al
Got this done today. Pretty simple just need a vise. The Kubota seal kit only had one rubber o-ring and one nylon o-ring that goes on the side that threads into the tractor. There are two more o-rings on the quick connect side that are different sizes than the other end.
The picture is with the coupler fully disassembled.
7,323
How do you get the BB's back in? Some grease so they stick to the outside?
JasonW
799
554
Al
I thought I was going to have to use the grease trick but I just stood it up on end and they fall on place.
11,758
What's the diameter of the black and nylon seals? Curious if mine are the same. Also, I assume that you didn't need to remove the spring loaded collar in order to replace the two o-ring/seals on the other end of the coupler.
3,831
2,384
Did it fix your leak?
JasonW
799
554
Al
I would say yes and no. Ran it some tilling up the garden and one was almost pouring fluid. Disconnected the hoses and found a piece of the nylon o-ring.
IMG_3298.jpeg Disassembled that coupler to find it had pinched and rolled over the rubber o-ring.
Reused an old one(both were pretty mangled from pulling them out with a pic) and it appears to have fixed the leak on that coupler. But now the other one has started to seep. I haven’t taken it apart yet but I suspect it may have been damaged during install.
They were lubed with hydraulic fluid but they might be that fragile. So for now it’s to be continued.
JasonW
799
554
Al
Update. Well after three sets of seals the leak was actually worse than before, It was about 1/2 gallon every hour. Upon disassembly the nylon o-ring was damaged every time, they were put together lubricated and centered. All surfaces were smooth so I’m not sure what was happening.
Time and money ahead to buy new couplers. Guy I spoke to when ordering said it could have been the outer quick connect side seals(which Kubota doesn’t sa leaking and the fluid was coming out of the back of the coupler.
Bought new couplers and can confirm they are 3/8 British pipe thread. Best I found was about $50 per coupler plus shipping.
Like Tractors
Several Kubotas
Jan 1, 2020
99
152
Eastern Iowa
My M5-091 uses the break away couplers and they have leaked from new, I replaced one, still leaked. I cut a plastic oil jug to fit under the couplers to act as a catch can, problem solved. The plastic jug just happens to be gray in color a very close match to the Kubota gray.
Pioneer couplers on the IH tractors back in the 70s didn't leak they were break away couplers also, just a much simpler design, they had only one seal. I should restore an IH 856 and use that instead, except I really like the other features of that Kubota.
