Rear remotes leaking
JasonW
722
468
Al
The rear remotes on my M6040 are leaking. They seem to be getting worse as now after about 5 hours the entire rear of the tractor is covered.
Searching here and other forums some say they can be resealed while others say just replace the entire quick connect.
I believe I have them narrowed down to Faster ISO A 7241 A fitting with a 3/8 male BSPP port thread.
Messicks has a seal kit for these that are about $12 for each coupler. Whereas new couplers are a little over $100 each.
11,427
I ordered and received a seal kit for the Faster couplings on my M6060 due to leaks.
JasonW
722
468
Al
Seen your post earlier about that. Where did you order those from? On faster couplings website it shows that part number is for 3/4” couplings?
11,427
I ordered from the following company after speaking directly with Faster customer service and giving all of the information I could find on the couplers. The person I spoke to told me that SK ANV 34 was the seal kit that I needed.
Dakota Hose & Fittings LP
P.O. Box 2220 | Fargo, ND 58108-2220
1287 47th St. N. | Fargo, ND 58102
Tel: 701.235.6484 | Fax: 701-235-3110
Toll Free: 1-800-949-4673
JasonW
722
468
Al
Thanks. I’ll give them a call in the morning. Have you resealed couplers like these before? I have not, but they appear to just thread apart
11,427
If you call, it's best to have the part number of the seal kit that you want. The guy I spoke to wasn't overly interested in doing research, so he was pleased when I told him that I knew the part number.
I haven't replaced any seals yet but based on the tool marks on the couplers on my tractor, someone screwed them in place using a pipe wrench. To be honest, the couplers look nice and the dust caps are nice too, but the website sucks, the numbering on the couplers sucks, having to use a pipe wrench sucks and so on. Overall I'm quite underwhelmed and actually annoyed by most everything about Faster as a company.
animals45
L3301l
Apr 22, 2021
282
94
Mabie CA
ya should be able to pick up new couplers at a hydraulic for 20-30 bucks each , & I think thats on the hi-side .
animal
jyoutz
Jan 14, 2019
3,574
2,675
Edgewood, New Mexico
animal
Yep. Most hydraulic shops can set you up with seals. And if you bring in the old seals, they will match them; no parts numbers needed.
11,427
@JasonW, what's stamped on your couplings i.e. what numbers and letters? No amount of searching on Faster's website turned up a coupling with the numbers on mine which is mind boggling. Perhaps Kubota or Land Pride has a contract with Faster and the couplings are marked differently. I measured the hex and the o.d. of the coupling and nothing matches anything in Faster's spec sheets.
It's entirely possible that the seal kit I have isn't the right one, but the woman on the phone seemed to know her stuff and was quick to tell me what I needed.
JasonW
722
468
Al
Need to know exactly what you have. Part number should be stamped on the coupler. I thimk the original has been superceded.
The male end that threads into the tractor has Faster 74/380 20N1.
Next piece has Faster 3CFPV-4SFPV 21AO.
Female end has Faster 3CFPV F-21BO.
JasonW
722
468
Al
Just left the local Kubota dealer they didn’t have any seal kits in stock. But they were $14 per quick connect. Parts diagram shows two seals per coupler.
6,782
The 3CFPV is obsolete and replaced by 4SRHF. I dont recognize the 21B0 thread type. Dont the female couplers screw directly into the valve on the tractor??
JasonW
722
468
Al
No the male end 3/8 BSPP goes into the valve block on the tractor.
This is what I found from an older thread that you responded to.
6,782
Yes, the female coupler has a male thread end with o-ring that screws directly into the work ports on the valves. If you are certain the thread is 3/8 BSPP Valpariso will be the best price on the new 4SRHF replacement. I pay $35 for the female ORB version and use a male to male adapter to make the gender change.
JasonW
722
468
Al
Why change to a male to male? All my implements have male fittings.
6,782
You are not understanding this has nothing to do with the implement side.
The female couplers have a male thread that screws into the female port on the valve.
What I was describing was buying a coupler with female thraad and using a male to male adapter to convert it to male.
