BX 25 Doesn't stop well when cold/First use? Brakes and hydro.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I notice that my BX 25 doesn't stop well when it is cold, Braking seems better once the tractor warms up. This goes for the foot brake which feels like it has pressure but I can push it as hard as it'll go and the tractor will keep moving, Also when letting off the forward pedal the tractor doesn't slow up like it does one warm. Is this normal?
Thanks
9,247
You need to clean and lube all the HST linkage!
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
They work better once warm and used a couple times, I would not say they are the best brakes I have ever used but don't seem to really do anything when cold and by cold I mean winter weather. I don't hear or feel the motor straining and I don't feel its fighting the motor. Does RPM have any effect on the brakes?
I did use a low temp grease but I can Clean it better ( I believe it is clean )
9,247
The brakes might need adjusted, but the brakes will not override the HST being engaged.
If the HST pedal and linkage are telling it to go then the brakes are worthless.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
The pedal itself feels good with out a lot of free play but I can check the adjustment.
9,247
It's not free play that is the issue, you can move the pedal and thee linkage could be sticking and the dampener or the neutral holder could be keeping the HST engaged causing it to not stop.
Grandad4
Apr 5, 2016
404
150
Greensboro, NC
I notice that my BX 25 doesn't stop well when it is cold, Braking seems better once the tractor warms up. This goes for the foot brake which fewels like it has pressure but I can push it as hard as it'll go and the tractor will keep moving, Also when hp,ezz,z off the forward pedal the tractor doesn't slow up like it does one warm. Is this normal?
Thanks
The brake on these little BX tractors should not be needed to slow or stop the tractor in most conditions. Just taking your foot off the HST pedal should bring it to a gradual stop.
If you are having to get on the brake to get it stopped/slowed down, something in the HST pedal or linkage is not right, as the experts are saying here.
The HST pedal on my BX needed to be kept clean and lubed to work right and acting like you describe was always a sign that it needed attention.
Maybe there is more to your problem than regular maintenance, but that is step # 1.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
Okay, So just clean and lube the linkage? The tractor is kept clean and is in nice shape but the linkage could be gummed up a bit. Is there a write up for checking the adjustments?
9,247
Have you greased the pivot under the floor mat?
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
Yes I greased recently when i greased the rest of the machine, When I let off the forward pedal it seems like it takes a while to stop ( With out using the brakes ) I do believe that part is better when warm as well.
9,247
You probably need a new dampener.
Disconnect it, if your problem stops then you have your answer.
K2651-42150
xrocketengineer
Nov 14, 2020
824
766
Merritt Island, Florida
It might take a couple of laps at qualifying speeds until the brakes warm up and work properly. 🤪
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
Got it, Will do. It may be a little while before I get to it but I'll post back after checking.
nbryan
Jan 3, 2019
1,325
851
Hadashville, Manitoba, Canada
Soak the hst pedal linkages with WD40 and wipe/soak/air nozzle clean up the excess with a rag, then coat the assembly linkages with Fluid Film for long lasting lube and protection from moisture.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I ordered the damper as mine has a ripped boot, when I replace it I'll make sure to soak all of the linkages.
Is there a spring that is also supposed to pull it back to neutral?
Thanks
3,250
As someone else indicated above, most of us here with HST tractors rarely use the brake for anything but parking.
So my take on the situation is that the question might better be:
"Why do I have to use the brake to stop my HST tractor?"
My guess is after you replace the damper and ensure the pedal returns to neutral when your foot is removed, you will not be thinking of using the brake much.
Then perhaps you will move to another related question that comes up from time to time: Why does my HST tractor stop so suddenly? Or course if the damper is functioning properly you may not have this issue...
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
Would the neutral spring cause my issue? Is it in the front near the fan area? I'll take a look when i install the Damper.
