Hydraulic Hose Size for Auger?
5,296
Hey guys,
I'm fitting up a Chinese auger for my mini but don't know what hose size would be best for it. The auger came with 1/4" lines (that are way too long) and M14x1.5 ends and a M18x1.5 adapter that threads into the auger drive.
I have 1/2" flat faced couplers on my machine so I will need to add the same size coupler to the (new) hydraulic hoses to make the connection. I will need to get some adapters for the auger connection to hydraulic hose (M18x1.5 male to whatever I chose for hose side).
Since I will be adding new hoses of a shorter length should I step up the hydraulic hose diameter to 3/8" or 1/2"?
According to what I can find about the auger, it looks to have a flow rate of 8-16 gal/min. My machine flows around 14gal/min. The machine has a diverter valve on the dipper, so, I believe that I can control the flow rate the same way that I do for the hydraulic thumb.
Appreciate your suggestions regarding hose diameter.
3,241
1,853
I think @TheOldHokie included a chart recently, but I couldn't find it. So here's another one. If you're really pumping 16 gpm, 1/2" should be ok.
8,739
The larger the hoses the lower the resistance and lower the heat, so always better to go bigger on a hydraulic drive than smaller.
5,296
Thanks guys. Looking at the chart posted it would make sense to just go with the 1/2" line.
I only found one supplier (McMaster Carr) thus far that has the adapter needed to go from M18x1.50 to 1/2" NPT. I did get the quick coupler ears welded up to mount on the auger...this rig is getting freakin heavy!
1kubotakid
Kubota tractors and engines
Nov 19, 2013
24
Webberville mich
Hey guys,
I would use 3/8 minimum. Eric
