My B2620 mods
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
Finally got the last fittings to complete my hydro project so I could get the tractor out of the garage and backed up to the box blade to try out my widened quick hitch. OOPs needed more than just widening the hitch to make it QH friendly. Those bolt together braces had to visit with mr sparkey and that spacer just below the toplink hole had to go. So 2 cutoff wheels and a handfull of 1/8" 6011 and all is good my box is QH compatible. forgot to snap a before pic but after i spray some paint on it i will take a after pic.
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Heres my homemade trailer mover, it was a quickie project a while back so its not a spit and polish job but it works. I had to widen and lengthen it a bit this morning but now its quick hitch compatable. I hooked up to my 26' 7500# camper and relocated it on the property and was amazed at how the 2620 didn't even break a sweat.
jtb51b
B2320
Jul 28, 2013
Gardendale AL
Your rear remote setup is great. This is something I have wanted for a while but havent taken the time to move forward until now. I would love a parts list of the items you used (mostly the smalls) to make this a reality. Please email me at jbelcher@renorefractories.com if you dont mind. I will probably have a few questions for you if you dont mind.
Thanks,
Jason
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Ask away, you can email me if you want. Its my username at yahoo dot com
Sent from my DROID RAZR using Tapatalk 2
jtb51b
B2320
Jul 28, 2013
Gardendale AL
Thanks, I sent you an email. I really am just wondering what fittings and valve you used ETC. I can get lines made locally but driving back and forth to the parts house swapping fittings can get fuel costly.
Jason
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Diverter valve is nearing completion !
I capped off the curl and dump hard lines up on the boom where they transition from flex to hard.
Fed the original hard lines from the valve with hose (tapped back in with run tees ) to keep the original hard lines as crossovers.
The cover and its brackets are all made up just have to wait for the paint to cure.
Burtonbr
2012 B2620, LA364 FEL,rear remotes,grapple pallet forks, many other toys.
Nov 11, 2012
179
NC
I looked at the pictures you posted, looks good. A little different though, your going to be able to curl and use the 3rd function at the same time and did you use the through ports on the diverter?
bandaidmd
May 19, 2013
603
Middle of DELMARVA
the lines that come down the boom go into the front and pass right thru and come out the back unless you send power to the valve.
Once you send power to the valve it diverts to the top ports so its either reg operation or 3rd function, you cant have both at once.
Burtonbr
Nov 11, 2012
179
NC
RIGHT, RIGHT I see it now, I didn't see the lines going to the front. Very cool !!
get'er wired up and tell me how it works, I've been slack and just now got my fittings I needed.
Burtonbr
Nov 11, 2012
179
NC
Oh yea, the cover is a nice touch!
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Got a little more done and hooked the loader back up. Oops something went wrong the bucket only dumps with lever to right or left. Swapped the red and blue and alls good. Would have thought having them reversed would have just made them backwards? uploadfromtaptalk1376958183126.jpg
It would have worked with the lines the way i had them but i wasnt forceing the control handle over past regen. with the lines hooked up normally gravity will drop the bucket without the handle being pushed hard to the right.
bandaidmd
May 19, 2013
603
Middle of DELMARVA
I decided that a more compact form of rear weight would be handy, the box scrape works good but in a tight driveway pushing snow its way to easy to hit something shiney and expensive.
There was a nice plastic barrel and some pieces of steel that were just begging to become a project. uploadfromtaptalk1377471487832.jpg uploadfromtaptalk1377471504703.jpg
I might not be qualified to work tying rebar but there should be enough steel to grab the concrete.
There all ready to pour the floor on the new house across the street if I'm lucky the concrete truck will have some extra he needs to dispose of.
bandaidmd
May 19, 2013
603
Middle of DELMARVA
There was a nice plastic barrel and some pieces of steel that were just begging to become a project. View attachment 8264 View attachment 8265
Sent from my DROID RAZR using Tapatalk 2[/QUOTE
Lucked out and got my barrell filled when they poured the floor across the road ( to bad I didn't have a formed up pad ready he offered me 1 1/2 yards).
I thought my B2620 would lift a full barrell but was mistaken, had to shovel it out to just below the toplink.
9,616
Is that... or I should say was that a Fence from a table saw that you used for the top bar?
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Don't be looking at my junk lol
I put a real fence ( biesmier)on my saw years ago and while digging in the junk pile I found it.
9,616
That's too funny, I use Biesmier fences on my saws and router tables too! They help keep things nice and true.
I just spent 3/4 of my day butchering up some hickory for a 36" door, 2 inch thick with a full light.:cool:
Sorry... Thread Hi-Jack Over :eek:
Please continue with the tractor mods!;)
How much weight do you think you have in the barrel?
I was thinking of copying what you did but just using sand, I have a ton of it here!
bandaidmd
May 19, 2013
603
Middle of DELMARVA
There was prob 60 to 75 lbs of steel in there to start with and the concrete Truck driver said it was 1000 lbs for 55 gallon of concrete which seemed like a pretty high estimate.
kubota says my tractor should lift 1058 @ 24" behind lift point and the center mass of that barell is just about 2' behind the lift arms (i guess the upper lift arms are where they measure from?) so i guess its 900 at least .
You can see in the picture where my new level is.
