Fixing hole in side of block
Status
Not open for further replies.
L35
Jun 13, 2010
695
816
CT
I feel like with an extension or 2 on a 3/8” ratchet you could of got to that bolt on your starter without the need to remove your exhaust manifold, no?
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
formal introduction to your new best friend, reflection, burp of your earth
@L35
with the loader rails and everything in front of you, it is very tight to get that top bolt without taking off exhaust
you have no room in there, the bolt is stripped, it is just easier on your heart to do it this way
yes you are right though, if you had proper extension and angle adapter etc, you would have been able to get starter off without removing exhaust
_________________________
reflection: the molten bracket complex that kept snapping in half is no longer snapping in half
the bracket that you pump $50 or more of magic gas turning it into one entity, is magically staying
show me one person that believe that it is staying put? you can't believe it as you type it
you are talking about the rear bracket you melted the rebar/nails into, and you melted it together with the bracket that hold your fender
what you did yesterday and it somehow did not break:
you were LUGGING earth from the high point to the low point with puddles, in LOW gear, bucket all the way,
with insane MIGHT, you robot staying structurally sound, for hour and hour, diesel engine singing, calming down your heart
your suspicion: the rear bracket has less stress on it when your front support (that you melted the wheel spacer into) is intact, and since all the point of your loader connecting to your tractor are intact,
it spread the stress across all the mounting point, causing none of them big stress to break them
lesson: soon as one support break, DO NOT keep running it or you will snap your robot in half
underestimate you not how much might you need for your robot to lug around your realm and how much stress it cause on your steel structure
all your magic trick holding that hold your loader to the tractor, but the only magic trick that broke is your FEL valve
later today:
melt you a long steel rod/bolt/something across where your FEL valve weld keep snapping,
the longer the better, since it will spread the stress
you try to narrate this for the audience, that you cannot just melt 2 entity and expect them to stay intact, NO
where your weld break, you need spread the stress, and connect the 2 entity couple inches away from the breaking point (later you see what you mean with picture)
also you never got a proper formal introduction to your new best friend,
in few hour, you get a narrative that has been brewing in the bowel of your earth, deep inside your earth, coming to the surface, your new best friend , wait til you hear it
formal introduction
yes, here is your new best friend acetylene, in its natural state, witness you it
all machine come apart when lugging our realm year after year
machine will break into multiple entity from lugging the earth
then, the earth burp up a magic gas, after million and million of year sitting deep in the bowel of our earth
then you capture that magic gas, and it melt your machine back into its original state as being 1 entity
then your machine get back to shaping your realm for year after year
summary: with a tiny burp of gas from your earth, you reinstate the structural integrity of your machine, so you can gather gold and gold for year and year
woah
melt back your busted FEL valve together somewhat, then
melt you a new separate bracket that connect the part that keep breaking onto the steel rail (not the rod that it was connected to)
clamp you a couple bracket
why is acetylene your best friend?
it sat in the earth for million and million of year fermenting, then
it come out the earth to heal your robot, to get you the gold/wealth
it dont care about english language or any of the chatter in your head
cry you tear of joy when you discover your new best friend!
enough with the chit chat, finish you off your magic trick
melt your 2 random bracket laying around connecting your fel valve that keep busting to the big steel rail
hold you that big flame with 2 hand, your heart pointing and dictating the angle of the flame,
manipulating steel molten into low point until it successfully bind with your second entity
when that steel molten puddle bind with the intended point,
your heart and brain are also slowly reintegrating, healing from their damage,
slowly becoming one again
you being forced to sit there in this neutral state, deciding where to point the flame, the same is occurring inside you, meaning
in the non clench state of making successful magic, your heart recognize clench and start to ease, just like the steel easing its strength, turning to molten, connecting to the 2nd entity
it is a mirror - what you are doing with the big flame, the same is occurring to your heart/mind connection
woah
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
will your busted FEL valve hold? and rebuild your 2 leaky bucket cylinder
later on you find out if your 2 household bracket fused onto the big steel rail holding your FEL valve, will hold
you musta tried a magic trick 4-6 time already and they keep on breaking, you remember melting a long steel bolt thinking that would hold, nope
you are so addicted to riding your diesel Japan robot complex, that you cannot get yourself to fix the leaky bucket cylinders, enough already
be you like a Japanese artist if you fix those bucket cylinder
try to imagine it: your robot fully intact from all the magic conducted, and you have bucket control, without losing all your hydraulic fluid,
your robot controlling your bucket perfectly, lugging your earth with precision and control, robot staying structurally sound, diesel engine singing calming down your heart, eliminating your worry, putting gold in your pocket,
can you imagine it?
summary: let go of your addiction of riding your japan diesel steel complex, rebuild the 2 leaky bucket cylinder, shape your realm like a meek japan artist
your busted cylinder even come apart because you bust that long rod that hold it together when you took it apart aggressively
you melt 2 household bracket hoping your fel valve stop coming apart
because your an idiot riding your robot with the exhaust hanging, putting all weight on manifold,
your magic trick bust and is causing fume to disturb your peace when riding your robot, conduct you magic
the $57 dollar rebuild kit for your cylinder, you are grateful it come with locking rod since you busted all yours trying to remove them
your exact plan:
take off the cylinders, get you a table setup and chair, rebuild them properly, then
reinstall them back on, clear out all your plumbing issue, fill it up with hydraulic fluid, then test if they are not leaky
show you easy way to take apart your cylinder head:
put the pin in secure it to bucket, use you a big ol pipe wrench to take apart your cylinder head
you mighta put those packing seal backward but they went in way easier the way you see in photo
give it a shot, you used all your seals on that cylinder, you might need another kit for the next one
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
seal you a cylinder, bust you a hydraulic line
got your pin in mostly, then broke your pin, hopefully it hold
tool you need to get the pin in: sledgehammer and sharp chisel
reinstall your cylinder all hardware
turn on your japan diesel, robot move bucket, bust you a hydraulic line
it musta got wedged and torn
woah, no leak from your rebuild cylinder
go shape some realm and see if the bucket stay put (probably not)
shape your realm, lug earth backward, boom
now your lift cylinder come apart since maybe your pin/rod couldnt hold, unbelieveable
your lift cylinder bust open, make you a big ol hydraulic mess
what you can do:
take the pin out, try to get something else in of similar thickness take place of your busted locking pin/rod
also you can seal your busted exhaust manifold while thinking of what what to order/do
so far you need at least one hydraulic hose, a rebuild kit for your other bucket cylinder, and maybe more locking rod/pin
take out the old busted ring, go you through your scrap pile, decide to use a bronze welding rod
hammer in your bronze welding rod fit snug, lug around your realm for 1 hour,
woah, bronze welding rod fixed your busted open lift cylinder
unbelieveable
3,480
I have never thought that loader was the correct one for that tractor, but now I'm sure of it.
In the pic above that shows the bucket, I see two horizontal beams that just end in space in front of the radiator.
Aren't they supposed to be attached to something?
Maybe that lack of support is one of the many factors contributing to breakage?
Maybe kinda like these?
10,718
what you can do:
unbelieveable
You do NOT hammer the rod into place.
You insert the hook into the hole in the gland then turn the gland cap to wind and set it all the way around in the slot, locking the gland to the cylinder.
jaxs
B1750HST
Jun 22, 2023
1,033
793
Seriously Wolf you'll need a couple puffs off joe's pipe to grasp the whole picture the way joe does.
Reactions: 6 users
Sidekick
Jul 29, 2023
1,207
1,736
N.Y,
I'm surprised he didn't sand and repaint the cylinder rod...
There is enough sand in the hydraulic oil to do the sanding over time. Then add another magical coat of leak stopping paint. Joe is world famous now for sharing his alternative block fixing techniques 😬.
Hugo Habicht
G1900
Jun 24, 2024
1,510
2,161
Ireland
At this stage I ask myself if Joe has actually more sand in the hydraulic oil or more hydraulic oil in the sand ...
And I'd really like to know what he is smoking ...
3,376
We've all seen videos of repairs made in 3rd world countries, that actually work and sometimes we are impressed with the results, being so different than most in this country would ever attempt...
Can't help but wonder what people in those countries would think about Joe's approach...perhaps they would share a bit of amazement with us here?
Chanceywd
Mar 26, 2021
801
786
central ny
I just can't buy in to the taking the big ol pipe wrench to the surface of that inside piece that holds that stacked seal assembly making teeth marks on it. If it is steel it could score the cylinder bore. If aluminum just chewing the thing up needlessly and the potential for pieces to come off it and ruin the seals.
Hugo Habicht
G1900
Jun 24, 2024
1,510
2,161
Ireland
We've all seen videos of repairs made in 3rd world countries, that actually work and sometimes we are impressed with the results, ...
Yes, I would agree, and I have seen pictures of those repairs. But they would have known that any dirt, grit, sand, contamination is the ultimate death of any hydraulic system. They would have worked in the sand but still being meticulously clean (at least the ones doing long term successful repairs).
Joes repair may work for now but ultimately the hydraulics will fail with pump pressure decreasing, valve leakage increasing and cylinders starting leaking.
I am sorry, I thought initially Joe would manage to successfully repair this tractor, and I tried to give him support but he seems to be too advice resistant and wants to make his own (time and money intensive) mistakes.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
japanese assassin, land leveling 101
you ever know someone you thought was nobody, then they do something extraordinary and then you look at them differently?
you thought your japan robot hydraulic diesel complex was at its limit, then
your japan robot amaze you
in this photo, you have high point in center, swing your blade the motion of the strides in diagram
land leveling 101:
what you witness:
go you in circle backward, swinging big steel blade, along the hight point of your realm,
it will knock it down and plain out your existence
last time you did this trick with modern skid loader, overheated after 30 minute
you did this for 5 hour straight with your japan diesel, ZERO overheating not even close
you would even get the throttle up to 80% and just go for hour and hour
try THAT with your "modern" skid loader
icing on your cake: zero input from you, 2 wheel drive high gear, bucket slight up, your Japan assassin in charge now
the japan assassin, you look at your robot differently now
a puddle that you have been battling for 2 or more year, finally
could be solved by your rediscovered trick
have you a hallelujah moment when you solve your puddle problem
almost 60 page into your thread, and your giving land leveling lesson
unbelieveable
this is factory image of your loader, you can see they do have a beam connecting those 2 point
problem: if you put a beam there, you won't be able to open up your hood, it block it
maybe: forget the hood, do you a big ol magic trick putting a beam there, let it marinate
yes, agreed
get this: you even said that 20 or 25 page ago last time you were wrestling with your cylinders
what an idiot: you figure stuff out then you forget the protocol/method/trick
Status
