What kind of fuel cans / fueling systems are folks using?
papajoe
L3901DT Shuttle (2017), B6100E (1978), B6100E (1979), B6100HST-E (1985), RTV500
Dec 26, 2017
98
178
Oak Grove, La.
300 gallon overhead tank. Gravity flow. About as simple and as easy as you can get.
photowest
Kubota L3560LE, L3010, ZD1211
Sep 6, 2024
Indiana
The local farm bureau COOP provides me with a free 300 gallon tank and 120V pump and delivers refills of bulk off-road diesel (red dye, no tax) whenever I call. Cheap and super easy for me.
Chanceywd
Mar 26, 2021
738
680
central ny
12 volt HF fuel transfer pump and a 15 gallon barrel set on a 2 wheel dolly
I was scrolling thru looking at pictures and missed your description Skeets!
Bill
Chanceywd
Mar 26, 2021
738
680
central ny
Thanks NIW, I was scrolling thru and missed that!
A duh moment for me!
Bill
4,384
What pump is that you are using skeets? would like to make something like that, I have the tank and cart.
Bill
It is a 12 volt DC fuel transfer pump from HF, I think it was around 60 bucks when I bought it, one thing, it pumps fast I dont know what the flow rate is but it dont take long to fill a tank ! :)
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
I built a fuel trailer with a nominal 105 gallon diesel tank (nominal!) and a 50 gallon gas tank on a HF trailer:
Biggest mistake: Installing a 125 vac Filrite pump on the diesel tank instead of a 12 vdc pump.
I thought these tanks are only for combustible liquids and not flammable. I looked into setting our mowing trucks up with a similar setup since we moved from diesel mowers to gas. Caught some pushback from the higher ups, we’ve been using 5 gal cans.
9,464
You can buy DOT legal, Gasoline transfer tanks.
Chanceywd
Mar 26, 2021
738
680
central ny
I looked at them today they have gone up to about $140. I think I will wait for a sale and grab one.
I have a lot of arthritis in my hands so I am looking for a way to eliminate lifting the cans up high.
Just had an arthroplasty on my left thumb on the 13th so I won't be doing anything with this for a while.
Thanks for the info Skeets!
Bill
mdhughes
L3901DT
Dec 10, 2014
1,375
1,163
Ste Geneveive county, MO
My personal setup. 50gal and hand pump. Homebrew sight gauge.
What did you use on the tank for the fittings for the sight gauge. I have a meter on mine and a spreadsheet that I keep track of how much I put in and take out. I also use the spreadsheet to tell me how much weight is in the tank so I can figure how much fuel I can add when I take it to the station to "fill" it. The L3901DT won't pick it up if I fill it.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Weld in bungs. 3/4” or 1/2” for the drain and 1/4” for the gauge. Found them online. Www.Bungking.com
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
398
61
Wa
Danaidh
Kubota B2601 and more
Sep 11, 2024
9
10
East Alabama
I am set up similar to @Orange1forme. Six 5-gallon Mid-west plastic cans from Tractor supply and a battery operated fuel transfer pump. All Fit in My Truck for a fuel run.
I am not a typical Ag Farmer. I am our Family's land manager/Tree farmer. I mainly maintain what is there like fire lanes and roads. Occasionally, I build/repair a fence, move a log to my sawmill or create a new fire lane/road. I am not a huge fuel user over a 2–4-day tree-farm work event.
Tractors In order of importance:
- 2024 Kubota 2601with loader and 3rd function
- 2006 ~65 hp 4WD John Deere with loader
- 1988 ~65 hp Ford 5900
Kind Regards,
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
196
81
Waterford, Maine
It seems between the tractor, skid steer, backhoe and compactor that I am always running out of fuel. Granted I am doing the grading work to build a barn which will come to an end but I still think I want a better solution than 5-gal cans.
I see where flo fast has some 10gal and larger jugs but wonder if I really want to lug that up to the tractor top.
it may be that a pump system is warranted but that means something else to maintain.
want are folks on this forum using for the fueling storage and transfer?
I have a small BX tractor, so filling is done from several 5 or 6 gallon jugs. Like what most everyone has. I threw away the stupid nozzle that came with each jug. I have 6 jugs all seem to be different makes, and accumulate of many years. I was able to get replacement nozzle's from EZ Pour, that pour the fuel very quickly without the Hassell of holding some trip lever. Just pour. Another thing about the EZ pour product they make them for every type of jug. I have them on all my jugs gas and diesel. They also have adapters from one jug to another. Hope this helps. TSC has them.
