Interesting data on Engine wear vs prefilled vs non filled oil filter changes.
5,786
If you're careful you CAN 'precharge' the filter and NOT spill a drop. Have done that for decades with my A-C tractors, as have 1,000s of others.
it seems what's 'old' is 'NEW' again !!
je1279
Dec 6, 2020
828
585
Upstate NY
Is there a drain in that "bowl" that allows the oil to flow into a container without making a complete mess?
If it's anything like the Jeep 3.6, there is no check valve, so it drains ~95% of the oil back into the engine after just sitting for a bit.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,502
521
Well, looking at that pic of his video, he's already running the worst filters you can buy, LOL
Aside from that, use good oil, no worries. There will still be a film for startup.
trevoroni
B6000
May 24, 2023
201
251
No, but the cup contains the little bit of oil that drains out when removing the filter.
I usually just wrap a piece of paper towel around the base of the filter and crack it open while letting the oil drain from the pan and by the time it's ready for a new one to be installed the paper towel has absorbed all the oil that has came out.
6,917
Sit back a grab a drink - this guy will make you laugh your AO.
He does show some data that is somewhat against the typical grain!
This youtube video is not about oil per say - rather prefilling the oil filter before starting on fresh oil change.
AND maybe more importantly - how a cold engine that does NOT get to operating temps is the true demise of most all engines.
Check him out - be prepared to laugh, because he laughs at himself!
Very informational video.
I had to go into setting and adjust the playback speed to .8 so I could get him to slow down! He's wound up like an eight day clock!
5,502
2,209
I have tried to scientifically test prefilling the filter by using the oil pressure gauge response time
there was zero difference between prefill and not prefill. Dart SHP 9.5 deck SBF block, standard volume pump, 0w50 oil and about 95 deg F air temp if it makes any difference
remember you still have to get the pump to suck up the oil from the pan first, and when you drain the oil out of the pan, most of the oil in the pump and pickup also drain out. Then when you fire up the engine, that "dry" (not really but it isn't "pre-charged") pump and pickup assembly have to refill, and that's the suction side of the pump which is slower to charge than the outlet side is. The pressure passages in the pump, relief passage(s), block, crank, heads are all still mostly full as they don't readily drain back, well unless you let it sit for a few months and they might but if we're doing an oil change we don't let them sit for months to drain do we?
if you have a good 0-100 digital gauge you'll see that there is a little bit of pressure right away, typically 1-5 psi, and in a few seconds it comes up to normal.
but here's my take on this, as usual when forums discuss anything oil, they get all technical and stuff, and the knowledge is based on what we have read on other websites. It starts a war a lot of times and generally I don't get involved. But I've been through this both with engine training and with engine lubricant training at a former job (training done by the manufacturer). What people don't often think about is if you leave your, tractor in this case, sit in the barn for a few weeks, everything drains back into the pan and it takes longer to build oil pressure after sitting than it does if you do a normal oil and filter change. But we don't talk about that, for one there's nothing you can do about it. Well I guess one could install an oil accumulator to precharge the system before cranking, but again I don't know if that really does much good since the manufacturer designs the engine specifically knowing that a low/no pressure situation is GOING to occur after an oil change and/or after sitting for lengths of time. Even on my race car, an accumulator is useful for peace of mind but it doesn't make bearings and rings and such last any longer than without them. It still goes to 0-5 psi during shut down and stays like that for about 5-7 seconds, starting at 7800 RPM and backing down to about 2000 there isn't much oil pressure. In decades of running it, it's never caused an issue that I can see.
I've driven broken tractors from the back side of the building (at the old job) to the shop with zero oil in them. Fill em up after a pan replacement and they run for a long time. At one point I was given a BX2200 that was a total loss, but engine ran fine. Couldn't sell it, nobody wanted it so I did some of my own testing. Engine ran for over 40 minutes with zero oil in it until it finally just got so hot that the pistons seized in the bores-it never started knocking or anything. Let it cool off and for giggles I fired it up and it ran another 10 minutes. Just gave up on it, shut it off in amazement and went to bed. Next morning I had a response to the marketplace ad that I had the tractor listed on, guy wanted it for parts so I let him come get it. As said I couldn't sell it but there wasn't anything saying I couldn't give it to someone else.
