RB2684 Rear Blade - can I shorten the blade?
MrScott
Bx23s, Bx2680 (front snowblower), Box blade
Jan 22, 2025
Alaska
Have opportunity to grab a land pride Rb2684 with hydraulics for cheap....$250 cheap!
I have a bx23s which is WAY too small to handle an 84" blade.
Thinking I can just cut a foot off each side of the blade and turn it into a 60" or even a 55". which is probably manageable.
Land pride recommends the cheaper/smaller RB15 series for my little toy tractor. Is there anything about the RB26 series that would not mount to the 3 point hitch on my BX?
This is my cabin tractor and used to clear snow on 1500 foot of driveway. Primarily use the front snowblower but can't pass up the deal for a rear blade if it will work.
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
I mean I guess you could the price is right. But I’m thinking it’s still gonna be too much for the bx. The 26 series is beefier and I believe taller moldboard. But to answer your question no it should hook to your tractor unless someone fabricated the blade to go to cat 2 or 3.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,939
2,337
Western MT
Buy it. It's not that heavy if you look at the specs at the landpride site. You'll likely only save maybe 100 lbs.
When you angle it, the width will be helpful. But, if you want something lighter, I'd trade it to a dealer. It will like be easier than cutting the wear bar and blade then finishing it.
I use the same width. Sure, my tractor is bigger.
MrScott
Jan 22, 2025
Alaska
Thanks guys. I'll go buy it. If for some reason it won't work I suppose it will be easy to sell and get my money back.
Mitjam
Jan 14, 2013
348
420
Sounds like a heck of a deal as long as it not bent, not too much can go wrong with a blade even with some paint you could prob make a good buck or two selling it if need be. Good luck
6,285
buy it, install it, swing it , mark it past tires a bit, remove it, cut the ends of it, reinstall it
now go have FUN......
PS keep ends to make 'bolt on box blade ends'...
MtnViewRanch
912
373
Lakeside Ca.
Good luck with being able to pick the blade up high enough to be able to actually go and make use of this blade. Nothing to do with the weight, simply that your 3pt will be raised just about all the way just to get hitched up.
Buy it and sell it. It is to good of a price to pass it up.
11,757
This would be my concern too. I recently bought a used Buhler/Farm King three-way hydraulic blade Series 80 that weighs around 1,000lb and paid $3,600 (new is twice that) so this LP RB2684 would seem like one heck of a deal. For the record, the M can raise the Buhler two or more feet off the deck so not an issue.
I'm not sure if this blade has three-way hydraulics, but the cylinders alone could be worth the asking price. I would absolutely buy it for $250 even if it were lawn art for a few years.
Added in edit: I see that the 12" of blade offset is accomplished by unbolting the blade and moving it left or right 12" so not three-way hydraulics, but still a great buy given a new one is probably around $1,500.
