Have the chance to buy a b7100 very nice with loader but no engine. Also can buy a b6200 with running engine but 2nd no loader. Will the motor in the b6200 a (850) fit in the 7100 (750) any advice helps
Thanks for the fast reply I’ll keep you updated, would the loader from the 7100 fit a b200Yes, the external block size is the same and mounts are all the same along with flywheel mount.
You just might run into a slight twist.
1/2 of the b6200's were a thermosiphon system, and the other 1/2 were a water pump and thermostat system.
Both will work but if you have a choice you want the Water pump version.
I can tell you how to alter the radiator very easily to fit the water pump or you might be able to use the B6200 radiator.
6200*Thanks for the fast reply I’ll keep you updated, would the loader from the 7100 fit a 6200
That would depend on the loader, some did cross over.Thanks for the fast reply I’ll keep you updated, would the loader from the 7100 fit a b200
Hello, mind sharing how to modify rad as mentioned above. I purchased a b7100 with the d850 already installed and not running. The lower hose was kinked badly. Currently, I installed a reinforced hose and made a loop. Not ideal, but it works. The real solution would be nice.Yes, the external block size is the same and mounts are all the same along with flywheel mount.
Thats a b219 loader. It will not directly bolt on a b6200. Subframe is one piece and would have to be extended for the longer frame of the 6200 and the front pto pump setup may have to be modified a littleThanks for the fast reply I’ll keep you updated, would the loader from the 7100 fit a b200
@Mountainman you have been stung by dead thread posting, look at the date of post 6 then look at the date of post 7.Thats a b219 loader. It will not directly bolt on a b6200. Subframe is one piece and would have to be extended for the longer frame of the 6200 and the front pto pump setup may have to be modified a little
Ohhhh!!@Mountainman you have been stung by dead thread posting, look at the date of post 6 then look at the date of post 7.
