KX040-4 Mini Excavator Fuel System Issue
3,780
2,183
There's 3 sensors ! One unmarked, one gray, one black. So, question, which one was replaced and was it the proper sensor ? If it was the 'gray' one, did you SEE the gray marking on it ?
If you just 'bought and installed', it's possible it's not the correct sensor for that location.
Obviously those 3 sensors don't have the same charcteristics(temp range, slope,DVDT,etc. but probably will fit in any hole.
Those are exhaust temperature sensors. Their only differences are the cable's length and the connectors' color.
They do not require reprogramming the system, they are plug-and-play.
Diagmaster needs to be connected to diagnose the concern.
Pistol817
Kabota KX040-4 Mini Excavator
Jan 7, 2025
15
TX
If I am understanding correctly, the dealer is the only one that diagnose with the Diagmaster, correct?
rentthis
1,010
25
summerville,sc
I have had a similar problem with several other trackhoes. The problem was the connections at the water fuel separator. The brass fittings at the separator where the fuel hoses connect have a way of working loose and leaking air. If you can turn the brass fittings in the separator, they might be leaking air. If they are loose in the separator body, you can seal them with JJB Weld for a temporary fix. Replacing the entire separator was the repair. This seems simplistic but it has worked for me several times.
Pistol817
Jan 7, 2025
15
TX
Did you replace with OEM or just an aftermarket separator?
Pistol817
Jan 7, 2025
15
TX
Does anyone have a similar machine they could check the fuel pressure and see if what pressure it has? Does anyone know what the recommended fuel pressure should be? I cant find it anywhere.
6,323
I'd think the WSM would have those numbers. if not search the engine model info online, it'll be 'somewhere' in Cyberspace....
Hmm, come to think of it you ADDED a 2nd pump. which make/model ? Did you remove the 1st ( OEM ) pump? it might be that if you have two pumps, they could be 'fighting' each other.
curious , saw this RD41151353 as the 'pump', priced anywhere between $15 US to $245 CDN, looks similar to the BX23S one, so it's a 'lift' pump, maybe 5-10PSI ? I know my tractor runs fine without it......
Google found a post here on OTT, 5 PSI.. for the BXseries lift pump.
Pistol817
Jan 7, 2025
15
TX
I talked to the dealership and they don't think I have a fuel pressure issue, but I installed some clear tube and found air coming from the bypass line (see pic). I replaced all the rubber hoses and checked the check valves in this area. I was still getting air, so I just plugged the return line connection to the fuel supply. This basically just a recirculation line anyway. Now that air is goin to the tank return line. This should have the fuel issue fixed for now.
I guess I will need to take it back to the dealership and get the sensor error code reset for the sensor I replaced. Hopefully that will fix the regen issue and get me back in business.
Pistol817
Jan 7, 2025
15
TX
Thanks!! I replaced the 12V pump. I still only have about 1PSI not running and negative pressure when running, but that may be normal.
Pistol817
Jan 7, 2025
15
TX
I took it to a different dealership to get the codes reset. Diagnostics lead to an ECU failure as the issue. Yes, a pricey fix. I’m supposed to pick it up toward the end of the week.
6,323
yeesh that's 'complicated' fuel flow !! I don't understand the '#3 back flow' valve requirement. Any excess fuel should be returned to the fuel tank.
It'd be nice to hear WHY it's there, maybe an expert can explain, or link to WSM pages about it ?
xxmma07xx
Kubota kx040-4 excavator
Aug 6, 2026
NH
When you say you plugged tge
When you "plugged the return line connection to the fuel supply" do you mean the line going from the outlet of the pump to the suction side of the pump? Also where do you get your WSM? Mine doesn't have that diagram.
