Looking for some help. I have a 2022 Kubota xg850 sidekick. It had been running fine I parked it one night went out the next day and it wouldn't start. It cranks and cranks and eventually (just about kills the battery) it will turn over and run but will start hard if I turn it off. I installed a new battery , checked the spark plugs, cleaned the fuel injectors and made sure they were tripping. The fuel pump seems to be pushing plenty of fuel into the rails. I pulled the injectors out and tried to start the engine and they are barley, if at all squirting fuel. It is showing no codes that I can find how ever it did once flash a code about a coolant sensor error.
