BX23S - Wiring question for adding ROPS lights
bdh1966
19
Johnstown
Hi everyone,
I'm looking for some advice on adding LED lights to the ROPS. My question is surrounding the wiring that is provided on the rear of the tractor. I found three factory wires taped up and appear to be for factory accessory lighting.
One wire is hot to the battery, the second is hot with the key and the third appears to be the common wire. With that, here are my questions.
1. When I add the lights, do I need to add a relay? I'm assuming no since the factory added the connection.
2. Does anyone know how many watts this rear wiring can handle without overloading the circuit?
3. Any suggestions on a style or brand of on/off switch that can mount reasonably so the LED lights are not on unless I need them?
If this has been addressed in other threads, my apologies.
Thanks in advance!
bdh1966
nbking
L2501HST 4X4, Rtv-x900
Jul 8, 2018
222
73
Sonora, CA
You will not need a relay. Your wiring should be able to handle most led lights. I installed a couple switches on a bracket I fabbed. I got the switches and led lights from Amazon. I installed 2 forward and 2 rearward lights on my Rops. The lights are 27 watt each. I started a thread and had pictures, but not sure how to put a link in.
atitus
BX1880+FEL,MMM,Blower
Feb 11, 2019
144
21
Worcester, MA
One other thing to consider: I wanted to be able to turn the lights on when the tractor was not running, for example so I could clear snow or ice debris at night when snow blowing. I ran wires from battery to the rops, and installed that way. No relay, just got a waterproof switch that was rated for the current. Also, I put an inline fuse -- highly recommend this. If anything ever shorts, will prevent disaster.
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
322
27
23
Mobile, AL
I ran mine directly to the battery with a fuse and a relay. I got the harness on Amazon but had to add more wire. I did not want to make any electrical modifications to the original wiring.
tiktock
225
Plaistow
Not sure if the 23S is the same as the 1880BX but there's a wiring harness taped up and hidden under the back fender right near the PTO. Three wires there. One is a ground, one is on a "keyed" circuit meaning it will only put out when the key is turned on and theres an "always hot" line there too. I wanted the ability to use my lights now and then for quick night projects without turning the tractor on so I wired my lights to that "always hot" line. Mine was stock on something like a 20A fuse and easily handled my lights.
Should be around here on the BX...may be different or not exist on the 23S with the backhoe there:
Only downside is I have to be careful because my toddler loves pressing those pretty illuminated light buttons I installed. One of these days he's gonna sneak in, press one, and I'll come out to a dead battery I am sure but thats my problem and he shouldnt be on or around the tractor unattended in the first place.
7,457
Tiktock, if you're concerned about the youngster leaving a switch on, why not install a disconnect switch for the battery? Then everything is safe.
tiktock
225
Plaistow
I 100% agree with what you're saying. I'am also lazy so what I've told myself is that my kid shouldnt be anywhere near my tractor unsupervised in the first place so if he is and flips and swtich and my battery goes dead it will be my punishment for breaking the "no kids around machinery unattended" rule.
...but in reality I'm mostly lazy and just havent go around to it :)
woodacer
BX23S
Sep 16, 2021
Mass
I have a 2018 BX23S. I can confirm that the picture of the three wires is the same for my tractor. Solves my power problems for installing my Artillian ROPS LED lights.
Thank-you
5,165
I have a BX23S with the Curtis / Kubota deluxe cab and was thinking of hooking the hot wire permanently to the positive wire of the LED to the ignition switched wire at the rear of the tractor. Then I would extend the negative wire into the switch panel at the top of the windshield of the cab. Then that neutral wire will be hooked to a switch and from the switch back to the busbar that is located inside of the switch box. Is my idea a sound way of wiring the light? It will be protected by the Kubota installed fuse.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Don’t know how your tractor/cab set up. You can have the switch on either the power side or the ground side, doesn’t really matter.
Is there already a switch there? If so it’s probably wired as a positive switch so you would need to pull the feed off of it. Depending on the switch it may be backlit so you may need a power feed to that if you want that option. If its an internal feed for backlight then it won’t work on the ground side. Not sure if it matters to you, power would be switched from the key so wouldn’t matter if you forget to turn the switch off.
Personally not how I would do it, but it would work.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Also add, not sure what LED lights you are adding or if you have a radio, but a lot of them (cheaper ones) will cause interference with the radio.
5,165
I don't have a radio, so that isn't an issue. The only switch that was installed into the roof panel by the dealer was for the front LED lights, and that came with the cab. Kubota uses the Carling Technologies Contura II switches, and I had a bunch of them from a used boat dashboard, and that is what I used for the switch for my 3rd function valve. At the same time that I did the wiring for the 3rd function valve, I also put two more switches into the panel for future use. I only wish that they had cut the panel for more than just 4 switches. I have been looking for a metal hole punch that I could use to punch additional holes into the panel, however, I have yet to find one. When I get around to wiring the light, I will do it the way that you suggest. I already have circuit breakers installed in the holes below the switches.
peterbarker11
BX23S
Dec 22, 2024
Hi All
Think I already know the answer, but I’d rather have it confirmed.
In this location on the rear of a bx23s, taped up to the wiring harness there are two powered lines and one neutral line.
One powered line is on all the time and the other is ignition based.
Can i use one load lines for a switched rear drop sander, and the other for work lights and tie both into the same neutral line?
Again, I apologize if this is a dumb questions. I think its ok, but don’t want to damage anything.
6,223
yes, you can, providing total current doesn't exceed about 10 amps ( think that's he fuse for those wires... )
I used the switched one to power a 4 chnl wireless relay box( $15) to control my LEDs.key fob is on on cruise control lever.
peterbarker11
BX23S
Dec 22, 2024
Great. Thank you.
i found the “constant on” runs to a 20 amp fuse but couldn’t find the fuse for the ignition powered line.
I am assuming when you say don’t exceed the fuse allowance you mean 20 amps for each powered line and not in total?
Thanks again
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Check out rops lights. They are in Canada. Just got a set from them. Comes with nice harness and switch box.
6,223
I had a look at the wiring diagram and it appears that...
the constant 12 volt is the red/blk wire fed from the 20 amp 'work light' fuse
the switched 12 volts is the red/yel wire fed from the 15 amp 'DC outlet' fuse
I use the switched feed to power my wireless relay module.
The wireless keyfob controls are...
A) garage door opener
B) front ROPS lights
C) rear ROPS lights
D) unused for now....
