What size tiller can a B8200 run?
earthbuilder
Kubota B8200 HST
Dec 14, 2024
Chicago
I just purchased a B8200 HST 4wd tractor. Most tillers require more PTO hp than the tractor can provide. So what tillers are actual B8200 owners running?
jaxs
B1750HST
Jun 22, 2023
1,076
811
I wouldn't invest in anything larger than 36" until I tested it in MY soil.
11,042
The B8200HST are not really a good match for a tiller, too wide a stance, to little HP.
Even the smallest 36" is at the edge of what the tractor will be able to power.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
You are 16 PTO hp at best (probably slightly less since you are HST).
Using rule of thumb 4-5 hp per foot of tiller (for best results) then a 36"-40" tiller makes the most sense.
When it comes to tillers, much depends on the intended usage and soil conditions.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
Maybe on it's best day at joesmith's place
Does one have to till hydraulic oil into sand? Seems a beach rake would be sufficient to "level your realm?"
I would *think* Kubota probably geared the recommended 40" tiller for the tractor PTO, but do not have any experience with putting a tiller on a Kubota, I just happened to know where to look for the information. With that said, having tilled with a Simplicity tractor and tiller, a walk-behind tiller, and a hand-held tiller, I wouldn't go and till hard sod with it at a 6" depth setting, I'd probably remove all but one tine on each side next to the gearbox and carefully and slowly and carefully (???) break up the ground. Once the sod is loose then maybe put 2 tines spaced out on each side, still go slow, and keep working to pulverize the ground (sand, in Joe's case). With my limited tiller experience it seems the statements above, namely "it depends on the ground," are accurate.
6,286
providing the soil has already been plowed or chewed up somehow a 36-40" should be fine.
I ran a 36" tiller behind a FORD LGTR125 for 8 seasons. mid '70s tractor, Kohler 12 HP, burned a lot of oil but always did a fine job. If your tractor width is more ,not a problem, you need pathways to access the veggies anyways !
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Anyone using a King Kutter 4' tiller?
I have a four foot 'Ag-Meier' which is built almost identically to a King Kutter (pro model).
King Kutter 4' Pro Model:
My Tractor is only 20 PTO hp, but it will run the tiller just fine in dry, virgin sandy loam with native grass to penetrate.
This is video (recent) of a single pass with the tiller depth set to about 3.5"
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
I ran my 48" Howard tiller behind my B7200 just fine as long as I broke up the soil first. Best when the soil has some moisture in it. HST is a must so you can go slower if necessary. If you have clay and it has dried out it will be like cutting into concrete blocks. I raised up an area with clay this past summer for later seeding. I was only able to break it up to smaller chunks and had to level it out with fresh topsoil. So, the bottom line is it all depends on soil conditions.
earthbuilder
Kubota B8200 HST
Dec 14, 2024
Chicago
Thank you Ron. Much appreciated. Seems like if you have HST, you can go slow enough to not stall out the tractor. Worked for a small excavating contractor in another life. Only had 3 machines, so I learned how to take it slow to keep the working going without killing the equiptment.
GrassLakeRon
B8200HST-DP , RC60-82h Mower Deck, Woods RB6 Rear Blade, Homemade Carry All
Oct 27, 2023
319
194
Brooklyn, Michigan
I love my b8200. Love to see them work. All these people on the forum I have learned from.....glad to help.
FlatlandTransplant
B8200 with SSQA converted loader and a X300 yard tamer
Feb 18, 2017
24
19
King George, va.
I run a 53" in very sandy soil and it works. I go very slow but it accomplishes hat I need to do. I planned to get a bigger tractor in the future so I bought on the big end of tillers. It is offset to one side so you don't run over your freshly tilled dirt on the next pass. Mine is a caroni fl1300 I bought from agri supply. Their prices were better than used prices in my area. If the tractor could not run the tiller my plan was to remove some blades from one side to basically make it a narrower tiller.
murky
112
Vancouver, WA
I have a Rhino, I think 55" on my B8200HST. I think it works fine, only ever stalled maybe a couple of times if a rock gets stuck.
Looks like it calls for min 20hp. They have a 48" that says min 10hp. I think the Kubota manual lists implement sizes recommended. Probably says 48, it was years ago that I read it.
I also have stump grinder that recommends 15 hp min I think, and the B8200 struggles more with that than with the tiller.
