Only about ten drops a day appear beneath my L3710, so topping off is infrequent, but along with the sloppy bushings shown in my video above, the situation will only get worse.  The steering cylinder is allowing fluid to seep past both seals so needs to be
rebuilt or replaced.  The hydraulic hoses appear to be sound but replacing them might be prudent for peace of mind.  The pitman arm may be a candidate for repair but likely should be replaced.
			You usually have to ream the bushing after replacing it.  Or just get the whole pitman arm that has new reamed bushings already installed.  Make sure to get the pin too as it is usually worn as well.  There's possibility that the bracket that holds the pin is worn/oblonged, so you might want to look at that before ordering parts.  There is a thrust washer between the pitman arm and the bracket, it also wears--I've had to dig around and find  thicker washers in the past to take up most of the clearance.  You don't want it "tight" but you do want to remove most of the slop.  Kubota should have offered the washer as a selective shim.
Takes a hydraulic press to remove/replace the bushings and this repair can only be done if there is a bushing left in the arm.  If it's worn through and into the arm, you have to get the arm.  Replacement arm is updated.  I don't know what they updated, just know that the part number changed a few times since it came out in 1990-whatever year it was.
Even after pressing the bushings out/new one in, a lot of times the bushings are mushroomed just a little so you have to ream it. If you don't have access to a press and the right mandrels to use with it, and a reamer, you may find it more convenient to replace the whole arm assembly.
So, even excluding labor (I don't have a press, mandrels, reamer, etc.), this could get unjustifiably expensive (below are current Messick's prices for my 1999 tractor with serial number >= 50009).
For the pitman arm
definitely:
160 TA040-17250 WASHER $12.62
060 38240-13160 SEAL OIL $10.69 x2 = $21.38
090 TA040-17210 WASHER $12.62
and either:
070 52200-22430 BUSH $17.00 x 2 = $34.00
plus labor, or:
040 TA040-17132 ASSY ARM PITMAN $384.09
and possibly:
020 TA040-14310 SUPPORT SHAFT / SKIRT $116.24
and probably:
150 TA040-17162 SHAFT PITMAN ARM $105.51
190 TA040-17173 SHAFT ROD END $63.43
For the steering cylinder
definitely:
080 TA040-17200 WASHER $8.09
050 08511-02420 BUSH $8.47
and either:
110 08511-02420 BUSH $8.47
plus labor, or:
100 TC059-17100 ARM PITMAN $156.46
and either:
030 TA040-37570 GASKET PISTON $20.97
040 04816-00450 O RING $6.62
060 08511-02820 BUSH $10.05 x 2 = $20.15
110 08511-02512 BUSH $8.94 x 2 = $17.88
120 04817-50500 O RING $5.73 x 2 = $11.46
130 TA040-37560 GASKET ROD $20.97 x 2 = $41.94
140 TA040-37580 SEAL $29.62 x 2 = $59.24
plus labor, or:
010 HTA00-37800 ASSY CYLINDER STEERING $1,579.00
I remain unsure about attempting this myself (labor would be
significantly more if I don't), but assuming the
LA681 dismount goes smoothly, I likely will proceed once the cost is justified (not yet, as both the leak and the steering slop for this off-road-only tractor are tolerable)!  Regardless, thanks again for sharing your experience with both tasks.
