Give me Tips on Removing, Rebuilding L3710 Steering Cylinder
MOOTS
MX6000
Jun 27, 2019
2,156
2,661
Canton, Georgia
You pay 'em $20/hr (to throw a number out there, ain't too many who'll work for $20/hr now unless they're entry level).
I'm less than $20/hr. I keep 45-50 pieces of turf equipment/mowers/field rakes running. And probably the same amount of weedeaters, chainsaws, blowers and small single cylinder engines.
In our division, I am the 3rd down the ladder. Director, manager, mechanic and turf specialist, crew lead, worker.
And we just raised the worker from $11.33 to $15, crew lead from $16.40 to $17.50 and cant get any applications. They promised a raise for me and turf guy by October, we shall see.
I really don't know why I typed that out. Lol. Your sentence hit a nerve I guess.
Mr Haney
L3710, ZD326S
May 23, 2022
297
79
FL
I still have no tractor. Everything went well until I put the cylinder back in. I made the mistake of moving the steering wheel to move the cylinder so it lined up with the locating pin, and the rod hit my front gear case cover and knocked a hole in it! Engine oil started coming out, so know I can't start or move the tractor until the hole is repaired.
I got a new (old) gear case and cleaned and painted it. Now I'm waiting for the mechanic I called to install it. No word in two days.
Thought I would improve myself and save some money by working on my own tractor. I can't say it has worked out as well as I had hoped.
bjmsam
L3710 HST, G1900-S
Feb 19, 2010
15
Mount Airy, MD
The steering cylinder on my L3710 has been leaking for years, and I found this thread while preparing to tackle the job myself, but I'm admittedly discouraged by your experience.
Mr Haney
L3710, ZD326S
May 23, 2022
297
79
FL
You'll have to remove the radiator, which is not fun but not a terrible job. I suggest drilling the hole I mentioned above to get access to the hidden bolt you will have to take out. You can paint around the hole later to prevent rust.
Above all, don't use the hydraulics to adjust the position of the rod without attaching the cylinder at the rear to keep it from going through your front engine cover. I think it's best to have someone else watch it as you turn the wheel. If the cylinder goes through the cover, you will end up spending around 10 times as much as a cylinder repair would cost. Attach it at the rear and then adjust it to attach the front. That's my opinion, anyway.
I believe I had the shop write down the figures for the seal parts so I could avoid paying Kubota prices when it fails again, but I don't recall whether aftermarket parts were actually cheaper.
