Fixing hole in side of block
Status
Not open for further replies.
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
The way to fix that type of leaking is to put a coffee can under each leak with a fishtank pump back to the hydraulic fill tube.
3,590
got the ring out, rebuild cylinder
So, disassemble & clean all parts, check bore for size & pitting, (and if within tolerance) hone bore, polish ram, replace wear ring, replace all seals & o-rings, replace spring key, lube all parts with clean hydraulic fluid, and reassemble, and pressure test.
Right?
3,590
You know, maybe it's the holiday season, but whenever I visit this thread, I get a hankerin' for some cookies some relative of mine used to bake:
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
make hydraulic progress, comprehend the value of the reward
grind down the threads since you couldnt thread on the head
remind yourself that these machines cost 20-25 thousand functioning properly for a reason, meaning
of course the tasks would take months and months and thousands of hour of all of your might
a good functioning loader with all the hydraulics properly functioning of this grade is probably around 6-7 thousand dollar
give you it a second to come together, dont think that you can seal of those leaks in a day
clean you it up with everything, seal you up all the areas there are seals, hammer on the top, seal it shut, put you a ring
strike and strike, torch and torch, got it down to this point, wont go further
exhausted from striking, come you up with better plan using whats laying around
I'm thinking: set it horizontal couple feet above ground, with one end up a against a tree, drive you pickup truck straight into it
another idea: bx1500 cannot move, but it can move its loader
set you up your cylinder upright, crush down on cylinder with bx1500 loader...
Didn't work
Go get you a press already
solved, I point to the part you hammer on to to close up the cylinder
You had the other end completely in, thinking it needed to go in further
your definitely slow for forgetting that but glad you got it closed up, install ring, get going on the last cylinder
show them some midday magic to bring the mood up of thread
tons of things done wrong in this clip: you come in too soon with the bronze, way more heat on the pin, aim the flame mostly at the center of pin, get the pin 4 times as hot as shown, do the weld with gravity pulling the molten toward where you want it, not angled, start the puddle on the pin, and melt it down to your other metal
you fixed the welds after this clip, they didn't hold, later in this post you see better weld
cannot get the ring in because hammering too hard on the pin area
grind down with grinding wheel and drill bit, hit it with torch and diesel, sledgehammer
the magic you witness did not hold
you had to go back in there with big flame
understand you the nature of the weld, you have a massive pin and a small piece,
hit you that pin hard hard with big torch, then drop you bronze on the pin,
and once bronze stuck to pin, gravity molten brought it down and connected it to your smaller metal
after you lay bronze, get you comfortable, hit it dead center facing down the pin until you make big molten puddle
that thing will be hot for 40 minute after your done, its always the same issue, more heat on the bigger metal to get it to accept the molten...
make progress, hammer in your newly welded pins, put back your hardware, your weld holding
connect hydraulic lines, get to the last cylinder...
take off your last cylinder, do the weld on the pin that you grinded away, then
systemically take apart and reseal the cylinder remembering all the mistake from the other cylinders
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
614
640
Lake Almanor, Ca
Ummm….what the hell happened to that bucket?
Each post has new, more interesting, ummmm….things😎
Sidekick
Jul 29, 2023
1,295
1,893
N.Y,
If you're going to bring monetary value into this minimum wage is about $20 an hour most places. If you are in the trades it can be double that. With probably over 2k hours so far and hundreds of dollars in fittings, hoses, rtv, torch gas, diesel, paint, oil, and parts invested you could have had a shiny new machine that would last 20 years after taxes if you had found a job. One that could actually be used for future income without constant repairs. Time is money and also one of the most valuable things we have in life. Guess you just enjoy playing in the sandbox smoking fatties.
Chanceywd
Mar 26, 2021
880
871
central ny
I have to wonder if this is a junk yard with that fence in the background, and these tractors were junked. Joe thinks he can bring them back to life, for future use or sale.
We have someone a few miles from where I live that has the same kind of fencing hiding something from code officer's view.
6,894
Thinking this whole thing is a long running joke. I suppose it is humorous on some level. Clearly not serious on any level.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
seal up your last cylinder, continue sealing hydraulic system
hit that pin real hard until red, come in with bronze, melt on the pin, it puddle down and encompass your other entity
you are so grateful for figuring out how to take out the ring,
hold the one side with pipe wrench, bend out the ring a bit, smack where I point with sledgehammer, it spin it out perfectly
how much do you love learning?
more than all their fake money combine
separate your last cylinder using pickup truck and tree, chains on both side, zero striking, zero effort
30-40 minute hitting cylinder nut with torch/diesel/pipe wrench/air chisel/regular chisel and sledehammer, fully seized
sit you down defeated, come you up with better setup
fully defeated, you cannot stand, it won for now
what it need: something gripping it with big force, then you get a massive pipe wrench, the one I have not ideal, and get you major leverage with it smoldering hot
let it marinate, save you some energy for sealing:
leaks at the transmission both side of pump and transmission
leaks at the valve, take off all ines, label them, seal everything
and hit the other leak with big torch hard and make it molten until you are sure it is sealed
and seal you up all the line coming out of injection pump
surgical seal of both clapped out transmission connection, at the engine and transmission, transmission line connected
now: seal your FEL valve., all 6 lines completely and surgically, then seal your diesel lines from injection pump to injector
label your 6 lines
take off all fitting
i point: these 2 thread do not fit properly, feel loose, wrong fitting, try to seal it
7,733
You have to understand this entire thread is pure entertainment. Consider the time taken, the book of pictures, the details in every movement, the obscene methods, and Joe acknowledges each post made. He's making sure it keeps moving forward, and we are all supporting that movement.
11,323
I think at some point I should require proof of life from joe.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,231
1,850
Pittsburgh
We could do the CAPTCHA thing featuring dead Kubotas.
Tarmy
Nov 17, 2009
614
640
Lake Almanor, Ca
Naw…just make him post a full on WOT tractor pulling a sled under the lights!
With fireworks.
I had a post removed about halfway through this…expedition. I merely pointed out that this is entertainment and cringe worthy all at the same time. Seems I wasn’t alone in that observation.
I nominate this thread for thread of the year…not sure what year….whatever.😜
3,590
I have to admit that following this thread is a lot like standing at a safe distance and watching a long, slow train derailment.
You just can't look away while it is happening, no matter how horrible it gets.:eek:
3,590
Is this a 50/50 mix of hydraulic fluid and water, or has Joe found a way to substitute almond milk for hydraulic fluid?
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Joe is demonstrating for the forum how AI impacts life!
all this talk of AI, but no one ever talk about HI
hillbilly intelligence
seal up hydraulic/diesel, give up on the last cylinder
all your fittings from your FEL, take them all out, glob it all in gasket, make them tight
there was nothing wrong with the fitting, you just didnt fasten it all the way
seal you everything
the diesel leak was so obvious, one of your injectors from all that pressure, come loose, you surgically seal it
decision: you were defeated by that last hydraulic cylinder, clean it, and glob gasket maker around the seals, and hope for the best
go ahead and reassemble your hydraulic cylinder, and your hydraulic robot should not produce bubble since you seal up all hydraulic route, and your engine should not sputter out since you solved the diesel leak
you should be able to carve earth today even if one of your hydraulic cylinder still leak a bit, the hydraulic system should not produce bubble and your robot should function fine
do you a hillbilly rebuild, glob gasket maker and hopefully the pressure pushes it into the leaking area
mistake, why you were not light on your feet:
all of those leaks could have been fixed in a day or less, you were heavy on your feet, striking away, not thinking
come you back to being light on your feet
brush everything with solvent, hit it hard with compress air, glob you on gasket maker everywhere there was leak, put extra hoping it pushes it and wedges it into the leaking area, hit it with torch to move the show faster
break your bx1500 front axle even more trying to push in your cylinder, push it up against a tree,
rig something up so it stay straight, calm you down and vow to never again try to rebuild cylinder without a press
your receipt that yes, this is a trainwreck
defeated by the cylinder, install it back on, tigthen all fitting, put in your hardware for the pins
hillbilly pin, you cant find this cylinder pin, get you a long socket that fit snug, rig you something that will keep it steady
rig you up copper wire tight around socket pin, temporary
pump you up that diesel pressure without compression, heat you up glow plug, get her started,
time to see if the leaks are gone enough to make hydraulics somewhat function properly
Chanceywd
Mar 26, 2021
880
871
central ny
I would guess that those 2 fittings are some kind of low pressure flare to flare or JIC to JIC 2 size couplings not the proper adapter for use on the valve body pressure in and return lines.
Just glad my surgeon used the right procedure and parts for my finger knuckle replacement operation last march and I didn't wake up in recovery with a mass of red silicone on my finger!
I think he avoided the hammer use too!
Status
