Hydraulic top link help needed
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
Backstory
I picked up the top link 2-3 years ago at the dealership parking lot. It was basically brand new. Guy had it for awhile and it didn't suit him. I offered him $100 and he took it. New, it was $350 Canadian back then.
Now
Anything in USD will cost me double to triple by the time it reaches me in Canada.
So for my initial hundred I'll see what the shop will charge to plumb it with a cv. If it's ridiculous, I'll just continue to use it without a cv.
As for the fittings, I think they are standard pipe thread.
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
I appreciate all of the help so far from everyone. I think I answered everyone's questions, if not, hit me again.
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
Dear OP,
Trust Dan.
He knows his sh!t.
Unless you are some type of "hydraulics Guru" that really knows whats up, you are much better buying one ......
Or, putting the DPOCV elsewhere (just as Dan advised me to do).....but I did not listen, and I should have.
here is my saga.......
https://www.orangetractortalks.com/...-to-shoot-ones-self-in-the-foot-part-1.63695/
Have fun at my expense, but listen to Dan.
Here is part 2
https://www.orangetractortalks.com/...-to-shoot-ones-self-in-the-foot-part-2.64941/
(y) 🍸🍸
I'll take a spin through this later.
If your local Princess Auto is like mine, there's a GREAT guy in the hydraulics department that'll grab ALL the necessary hoses and fittings, even MAKE the hose while you wait.
Our Princess doesn't do hard piping. Got another spot looking at it tomorrow
4,672
Your cylinder has SAE-08 ports. One option would be to disconnect the hoses and connect the C1/C2 ports on one of the block type DPOCV valves to the cylinder with a couple 12" hoses. Then connect the old hoses to the V1/V2 ports on the DPOCV.
DONE.
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
DONE.
Thank you Dan. I was going to post the pictures earlier in the the day but work has a nasty habit of interfering with fun time although work pays for fun time. It's a vicious circle 😆
1,450
One other thing to consider about installing the DPOCVs directly to the cylinder or having it remotely mounted if you have more than one cylinder (top and tilt cylinders for example).
If the valve is remote you can use it on any cylinder that you want to plumb it into. And you can have one cylinder controlled by DPOCV or both with no DPOCV in the cylinders lines at all.
If the valve is mounted directly to one cylinder that is pretty much all it can be used on (without physically moving off that one cylinder) and there is no float available for that cylinder.
It does look really nice mounted directly to the cylinder though.
MtnViewRanch
808
252
Lakeside Ca.
DONE.
Dan, are you sure #8 ports? I have never seen #8 ports on a 2" cylinder, typically #6.
MtnViewRanch
808
252
Lakeside Ca.
I'm not sure if your post is in response to mine above, but I would only disconnect the hydraulic top link If I wanted to remove it from the tractor, either to install the standard top link to free up a pair of rear remotes, or to put it on the shelf when running the folding cutter which connects to the draw bar.
Exactly, there is no reason to remove the hydraulic top link for the manual link. Set the top link adjustment fully retracted and disconnect the couplers. The hydraulic top link will stay exactly as adjusted when the couplers are disconnected. Just fasten the hose ends up out of the way with a bungee or the like. ;)
This frees up a set of couplers for you to use without removing the hydraulic top link.
mcmxi
6,502
NW Montana
With the MX and snow blower, I remove the hydraulic top link and use the standard link in its place, then connect the chute rotation and chute deflection to two pairs of rear remotes, and keep the hydraulic side link connected (FD valve) to the third pair of remotes and put that in float mode.
I'm not sure if this is what you meant, but are you saying that with the snow blower on, I could set the length of the hydraulic top link to get the snow blower adjusted properly, then disconnect it from the rear remotes, and use it like a fixed length top link. If that's what you meant, that's an interesting idea, and perhaps another reason to add check valves to the hydraulic top links on both tractors.
MtnViewRanch
808
252
Lakeside Ca.
Just to be clear, you DO NOT need the check valves to hold the cylinder in place when the couplers are disconnected. When the couplers are disconnected, the top links will hold their adjustment as they currently are, NO DPOCVs are required for the cylinders to be locked in place while the couplers are disconnected.
mcmxi
6,502
NW Montana
Ha! Ha! Now I'm following. It's been a long day! :)
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
Update: the valve I picked up wouldn't work out for me because of the way the ports were configured. I found another option the I'm going to try tomorrow and I'll get some pictures of my progress.
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
Here we go. I found a different valve in the Netherlands. $49 USD shipped to Canada and $23 Canadian duty. $52 at the hydraulic shop to make up some fittings. So all in all not bad on the cost.
I do need to get new hoses made. Both of mine were chaffed in a couple of spots on both hoses so I'm not going to use them. I'll get them made either Friday or Saturday, i wanted to test fit things first.
4,672
I will bite. What are the strange looking elbows screwed into the ports on the cylinders? I have never seen anything like them before.
S-G-R
LX3310
Jun 17, 2020
1,131
2,289
PEI Canada
The fittings that came with the kit were too small for the ports on the cylinder so he modified a pair by cutting the ends off and silver soldering the tubing into them.
