Fixing hole in side of block
Status
Not open for further replies.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Flush out your dlirty hydraulic lines, hopefully get your robot fix
i point to the input line coming into transmission from hydraulic pump
Take this off completely, get your engine running, pump all the fluid out this line, dont let that dirt and metal get into your transmission
Then once that main line fully clean, get engine running, go and start to take off completely lines that you want to flush out
Engine is running, take off hoses, move the FEL lever until you push fluid out those lines, clear out all lines and cylinders etc
please critique the approach to clean all your hydraulic line
clean up your work space, tighten you all the lines using all your wrenches
you'll never appreciate a hydraulic system until you go through and tighten each line, there are so many
tighten you all lines lines just enough to get your cleaning protocol going, not permanently
take off the end completely of the back end, where it will spit out
now: take off engine compression, spin you that engine make hydraulic pressuure, spit you out everything out that line,
from the engine, it go through all those lines you just setup, go through your FEL valve, and come back out the rear end
you're a bit nervous something not hooked up properly, open you up some ports so that if it is plugged,
it would not put all the pressure on the hydraulic pump and push hydraulic fluid into engine...
turn off engine compression, turn on your hillbilly ignition, open you up port on FEL valve, push you out that dirty fluid, rid your line of the bad stuff
now: close you up that port, but leave the back port open, pump you out that contaminant
yes, you got your receipt that, the line is circulating fine and is not gonna do that thing that wolf said,
where the line is plugged somewhere and you fixing to damage hydraulic pump
now, you can get your engine running, and open up the lines going to the cylinders, take them all off on one end, and
start playing with your lever pushing contanimant out those lines
since you have 4 cylinders, dont take off all 8 lines, just take one line off each cylinder and that hyraulic fluid should clear everything in the system...
articulate what just happen:
turn engine on, get you some hydraulic pressure, big leak right where you thought, the lines that could not flare
move you those levers, try to clear you out your cylinders, did not work because:
leaks are so massive, it cannot put pressure on that cylinder, and
since you have one side not connected, you cannot fill that cylinder up and then expel the contaminant
focus you on that big leak, at the lines that you couldnt flare, tighten up the rear connection, most connections
then, pump you some pressurized fluid into your cylinders, and yes the robot should move so be ready for that
then, open up those intake on the cylinder and the contaminant should come out
how you going to fix that big leak at those lines that you couldnt flare?
clean that area up with solvent, put you some carpet over the big hydraulic mess, first tighten them and see how much she leak, then if she still leak,
get under there with the aceytelene torch, and try to seal those leaks up since you dont have the right plumbing etc
fasten you all the lines on everything, nervous that the robotic might knock the tractor off of its blocks, put you the wheel back on
now: get her running, push your level up down left right, the robotics should move, since
the pathway will be completed for the fluid to flow, plan: get fluid inside your cylinders, then take out the back connection multiple time to try to push out some crud, and
take each connection off at the cylinder, allow some contanimant to get out that way,
be mindful and keep those eyes protected
tighten all the lines, put more pressure on the cylinders, they wont budge
maybe: they did sit out in elements for years and water got in there and seize the inside
either take your cylinders off and rebuild them, or spend $500 on 4 cylinders...
experiment: take you off couple cylinders, see if you can figure out how to take it apart, try to unseize them, you can even test them out not installed by rigging it up to the tractor
unbelieveable, your little weld job on the busted manifold holding, no black smoke dirtying up engine bay
another crazy surprise: your connection that was hard to flare is actually not leaking, I still cant believe it
spend an hour throwing everything you can getting the pin out, thinking:
"there was a zero percent chance that any of those cylinders were going to move after sitting 9-12 year out in the element"
get you off that second pin, take out the cylinder, see if you can take it apart
after 1.5 hour heating/diesel/chisel/sledgehammer, finally got your cylinder remove
take apart cylinder: at a glance, it need to be clamped down, get you a pipe wrench, try to loosen top,
look at diagram, see how it screws into itself, and then see if you can take it apart
you study this diagram until you understand how it come apart, maybe go hammer on that other cylinder pin and get that 2nd bucket cylinder remove
WI_Hedgehog
Apr 24, 2024
949
1,325
Milwaukee, Wisconsin, U.S.A.
Your flare tool and fittings, if typical fittings for that type tool, are completely inadequate and dangerous for this job. Don't do it!
Judging by the -one- video I saw of moving the tractor, anything more than a garden hose should be fine. (It's possible things changed since then and the engine is putting out more torque, that part I'm unaware of.)
This job isn't a Thai long-tail boat, it's a street repair (where anything can be made to run), painted to look like something it's not. Probably don't need to worry about the quality of the hydraulics at this point.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Unseize pins, clean out your cylinders
separate your cylinder using hammers chisels, vice grip, etc
look you inside your cylinder, filled with ton of dirt/metal
turns out, all that debris was completely blocking the flow of the fluid
clean you everything and put back together
definitely way easier than expected
the most seized metal I ever come across, torch like no other, hammering like no tomorrow, bring out the grinding wheel, went through an entire jar of diesel
1.5 hour later, finally got the pin out, unbelieveable
you cant stand up to do anything about anything, that seize pin took so much from you
get you contraptions to push that piston up and separate it
that seize metal took you out
Chanceywd
Mar 26, 2021
745
692
central ny
I may be wrong but in looking at the tubes you ran after cutting into the pressure line. If that first one is from the pump and you connected it to the right side of the valve it could be wrong. I would think that it would be on the left and the one going to the back of the tractor is your return. Yeah you introduce a lot of junk into your cylinders and they need to be cleaned but if those 2 lines are crossed nothing may work right.
Just passing thru and observing, by no means an expert on hydraulics, but have done my own .
7,144
Joe, I was going to mention the other day, when you have light rust like you showed on your grill....take aluminum foil and wad up some to make a ball. Rub this on the rust (like you're trying to polish it) and it will come right off.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
clean your cylinder, grind down where the pins hold the cylinder, mock it up and test hydraulic
clean you 2nd cylinder withouut taking out bottom pin, compress air and solvent, and files, etc, get all the dirt out
clean you out where the pins slide using hard wire wheel or big drill bit
grind down the pins so they slide easily, reinstall both cylinder, see if your cleaning worked
clean you out those pins, now they slide easy, put in your cylinder, fasten hydraulic line
Start you up your tractor, get you hydraulic pressure, play with the valve and see if you can move the bucket, nope
something still wrong
your finger touching the two lines to switch, you fixing to maybe try to switch the input and output you ran from your hydraulic pump into the FEL valve
switch you out those two lines, try again, nope
something else is wrong: maybe the route I have them connected is wrong
look at the diagram, see if your lines are proper
could also be the leak that you havent fixed yet
There is a smaller leak where I spliced the hydraulic line, maybe
that leak is stopping it from building enough pressure to move the heavy bucket...
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
diagnose hydraulic problem
fix you that leak underneath, you couldnt bend you that metal straight enough to get it to fasten properly, fix it
Spend you some time retracing each line
I retraced line 1 which is bucket down, its route:
Controller - goes to top of bucket cylinder, to extend it down
Line 2: go to bottom bucket cylinder
you did look at diagram and that is how they have it
Fix you that leak where you spliced, tighten you all the lines, raise the RPM a bit
I have seen machines unable to move hydraulics without big rpm due to many leaks
the leak is so big at the connections you couldnt flare, that
I pop off hydraulic line at the cylinder, and zero evidence of any pressure, meaning
the system cannot build any pressure because the leaks wont let it
fix you those leaks, then try again, there are a different non flare fitting available, try those, if not, weld you on your fitting and seal it shut, maybe take out the line completely to do your weld...
take you off the lines that have leak
weld you that collar onto the line in the position shown in photo
long as that collar seal to that pipe, your screw tapered fitting will seal that leak
do that for both line, maybe: hydraulic fluid in system too low to build pressure, put you some fluid and raise RPM for next try
weld you on that fitting you couldnt flare
grind it down enough so the female screw can go above it and make th seal
put you another weld on the outside of the female piece and the hydraulic,
make you your own plumbing, dont rely on the part store
This is the 2nd flaring that was leaking one of the harder welds you need to do:
bend you that line down away from tractor, get you in the prone position flame pointing forward, lay you that bronze trying to fill the gap, lay you on your side, bring the bronze in from back left and the flame from right side and melt you that backside that you couldnt see
if that weld dont leak, it would be a surprise
Hook you everything back up, no
Your welds did not stop the leak, both weld have tiny leak
Rethink your whole strategy then proceed
notice that it is not pushing out fluid, but air
Put you some hydraulic fluid, it gushes out the top get your new paint cover in transmission fluid
robot move!
put you 4-5 gallon hydraulic fluid, turn on your engine, pump sounded way different, had no pressure before, turn your levers,
robot start to move, pop out your two cylinders that you cleaned but you improperly put them back together,
there is a ring that I damaged and dont know how to reinstall that hold the cylinder from coming apart
lesson: sometime the problem way simpler than you think, go smoke you some fatty meat and the answer reveal itself
up close of you putting in the ring, it keep the cylinder from popping out
you mustve spent 1 plus getting those rings in, only in the end you found a way to get it in:
chisel it in, millimeter by millimeter, strike right where it enters
finally, you hook everything back up, turn on your engine
you can hear ton of hydraulic pressure in the system
you turn your lever to move your robot, that fitting you welded pops off and she shooting hydraulic oil high pressure, shut engine off
3,284
Is that copper tube? :eek:o_O
The maximum working pressure for a 1/2 in copper tube is 769 psi at 100°F,
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Just keeps getting better. Or worse, however you want to look at it.
Workerbee
Zd21
Mar 1, 2020
325
190
MN
Joe, your use if the term ‘you’ in everything you describe, makes it sound like you fancy yourself as the teacher. But before you can teach you have to learn. Pay attention to the advice lots have given you. Can you really afford to piss away all you have on two junk heaps that won’t function again, simply because you were going to do it your way?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,050
1,490
Pittsburgh
Bring a soil sample kit.
I am understandably curious.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
today could be the day you get your robot fix
get you under that tractor, fix you that line that pop off
might try to flare it again, and hit it hard with torch as you flare it, hoping somehow that help it flare enough to seal, if that don't work
take you off tons of brackets etc, get you that line off completely, then you can get a good solid weld on it
get these statement on the record before they are lost
your best weld will be right when you wake up, the first thing you do
even one disturbance of your peace will ruin the weld
the flame: you notice better result with higher proportion oxygen, a tiny strong flame off the tip will do the magic
if it glob up and does not want to get into the crevice:
dont forget @hagrid statment 30 or 35 page ago:
capillary, more heat on where you want it to bind,
and sometimes, you can just hit with flame, the big round glob, and it will melt into your desired area without the need of the rod in your left hand
(back to task)
grind you down where your fitting pop off, slide you in another fitting, fasten it tight
bend hydraulic line down, brush the area with solvent,
bring you out that big flame and make you some magic trying to seal it again
dont bend back everything into place until all those leaks are finished, use a hydraulic hose and get engine running, see if she still leak
"you happy now? finally got your robot fix"
that weld you just did has zero leak, take you off your other leaking weld and fix it, reinstall it, then
go carve you some earth
make you your own plumbing, eliminate any chance of leak, do big oxygen and tiny acetylene
let it cool down, dip in bucket of water, install it, see if it still leak
you aint carving no earth
ton of leaks: bottom of 2 cylinders that you cleaned, tiny leak on your last weld, leak where input into transmission, might have dropped the seal, check it again
you want to carve earth but you cant, leaks are too big, also
it has big trouble lowering the lift, it almost want to shut off engine, why?
Fluid inside so dirty, it is messing with the flow of hydraulics causing system to come to halt, ie straining the engine
does not happen with the cylinders you cleaned
carved you some earth, hydraulics now fully stuck, i dont think it is low on fluid but maybe, keep carving earth
later: take out all loader cylinders and clean them and seal them surgically, now
enjoy the machine doing the work for once
3,284
No need.
Soil will consist of diesel, solvent, paint residue, grease, hydraulic oil, motor oil, grinding dust, bronze brazing blobs, sweat, lost parts, and sand.
(proportions may vary)
:);):LOL:
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
No need.
:);):LOL:
Might add blood to that list ;)
6,007
No need.
:);):LOL:
You left out blood. This is my first and last time looking at this thread. Somethings you just cant fix.
Dam
Status
