L3650 starter stud size ?
johnh25
L3650
Nov 21, 2024
Fl
Working on an l3650 and it's missing a starter mounting bolt can't find the specs and can't seem to find one for sale anywhere and help would he greatly appreciated
3,002
Go to your local dealer and they will probably have some of it in stock.
Dustball
2016 B2650HSDC
Sep 15, 2023
519
383
Hudson, WI
M10x1.25
30mm length for the bolt.
Looks like 42mm for the double ended stud.
3,002
M10x1.25
How did you arrive at that information? I have not seen that type of information tied into the part number so you must have better information than I can find.
Dustball
2016 B2650HSDC
Sep 15, 2023
519
383
Hudson, WI
The nut that is called out for that stud is 02176-50100. Searching Google for that part number returns multiple results that include the thread size, M10x1.25.
Example-
The bolt for one hole of the starter is 01133-51030 . Searching Google for that part number returns multiple results that include the thread size and length, M10x1.25 x 30mm.
Example-
The stud's part number is 01517-71030. I used Messick's picture of the stud next to a ruler and drew parallel lines from the ruler at the start and end of the threads and came up with 42mm.
New info since I posted. 01517-71030 replaced 01517-51030.
01517-51030 search results show that it's M10x1.25x41mm so I was 1mm off.
3,002
Thanks for the search method.
7,313
My bad, I'll do better next time. 🤪
I was pleased that I could figure out LED equivalents for the tractor's lights.
Looks like a similar method to find starter bolt and stud specs, but much more involved.
Great pointers for all!
