BX Fixed lift 3PH
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
208
181
Westford, Massachusetts
shelkol.com
I have a BX2200 and use a weight box on the rear while plowing. Sometimes I hit the lift lever by accident and the weight box falls. I see there are places to hook the lift bars to the tractor and not the lift. If I just moved the lift bars over, the weight box would be too low. Do they make shorter lift bars or do I have to make my own.
Does any one see anything wrong with keeping the weight box up for the winter? The box is about 700#
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
222
236
Pennsylvania
I could be wrong but, I think you are 400 Lbs over the recommended weight for that box.
Donystoy
Dec 10, 2013
667
302
Binbrook, Ontario
Does the BX not have adjustable stops on the control lever? Even my b7200 had them. If not, you can probably make something and would be easier and cheaper that making new lift bars
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
226
67
NE Wyoming
No stops on a BX2200. There is a valve to control the drop rate that can be completely shut to hold the
3-point at the desired height. Sitting in the seat its the knob behind your right leg.
shelkol
Nov 12, 2015
208
181
shelkol.com
Yes, I kind of remember that, I'll have to try that. Thanks
8,793
It's actually a home made 'box', a beer keg. The BX2200 is rated to lift something like a 1000# on the 3PH
Actually 684 lbs is maximum lift capacity.
So you're a little over but close enough at 700lbs.
And yes the best option without any alterations is close the three point lift control knob.
WI_Hedgehog
Apr 24, 2024
660
864
Milwaukee, Wisconsin, U.S.A.
I use the valve as @Dustyx2 mentions, to answer your question a person could use Limiter Chains.
The BX can lift "something like 1,000#" if it's centered at the factory lift points.
(not your exact BX but for reference)
8,793
Limiter chains on a BX is problematic because the strength of the upper point is already low and adding that kind of force can break the housing.
Some BX's had attachment points on the bottom of the ROPS, I'm not sure if this one did or not.
The EXACT BX for reference:
shelkol
Nov 12, 2015
208
181
shelkol.com
Yes, The weight in the box is centered on the eyes in the 3PH lift arms. It is not hanging off the back. Since it ids an old beer keg I've always wanted to run a hose from the keg into the cab just as a joke. I will try closing the valve.
Thanks
3,679
If you have young kids/grandkids running around you might want to be cautious if keeping it in the air when not running.
Love the idea though (y) (y) (y)
