BX25D lack of movement solved
john piper
bx25d suv
Nov 17, 2024
NSW Australia
I could barely move forward or reverse. Front bucket working and oil level ok.
I found problem on you tube. The nut for the linkage rod (above the oil filter) was missing and the bolt was just hanging in there by a thread (excuse the pun) which was enough to make a slight movement possible.
Local dealer said (when I told him what I thought would be the problem) that would not be the case because he had been servicing these models for 3 years and never seen a loose nut there.
He had no spares so I bought a LOCKED 5/16 x 24 UNF for $2 from local fasteners, repaired problem in 10 minutes after R&R oil filter with no oil lost.
Glad I did not leave with dealer.
john
2,561
John,
Glad you found your problem! Those of us that have the BX25 and other models are very well aware of the nut backing off and losing some speed - mainly in reverse The nylon lock nut is the perfect solution too.
Like you, I had to adjust mine as it had backed off a couple of turns and the reverse speed was slowing.
Mark_BX25D
Bx25D
Jul 19, 2020
1,762
1,285
Ah, yes, the famous, "I've never seen it, so it can't happen! " approach.
That's how idiots think.
Glad you tracked it down. Hope I never need to know about it, but mebbe I should check mine!
Thanks for the info!
2,927
1,387
I have seen this on dozens of units and always use a Nylock nut to ensure it will not happen again.
Tractor Gal
BX23D MLB
Oct 30, 2020
483
138
NC
I'd like to look at this on my BX23D. It has always been quite slow in reverse. I thought that this was "normal." And, maybe for this tractor, it is normal.
I tried to go to messicks's to look for a diagram but wasn't able to find the correct diagram. Yes, I could look tomorrow...and will look tomorrow...but it's always easier to have a little direction. Plus, I'm hiding my laziness. Don't tell.
Tractor Gal
mcmxi
6,385
NW Montana
Tractor Gal
Maybe this will help ... maybe not .... but might get you closer.
Tractor Gal
BX23D MLB
Oct 30, 2020
483
138
NC
Yes, mcmxi, that does help. Apparently I didn't see the "speed change" category...or maybe it didn't register at the time. Now it does. Thanks for the help. I'll give it a look. Next thing I'll be reporting is that I flew backwards into the creek because the tractor speed was working better than expected. :cool:
TG
