hydraulic failure
14Cwater
b 3030
Nov 10, 2024
florida
i lost all forward and reverse in my b3030 hst, rear pto ans rear hydraulics dont work. The front hydraulics still work. After lots of searching I found the top of the motor has a blown out area that leaks fluid when i try to use the rear attachments. How big of a fix is this?
4,481
Assuming they can get it Messicks wants $1075 for a new top cover. Probably $1500 by the time you add shipping, gaskets, and any other small parts needed. Not a terribly difficult or lengthy job.
1,415
Yikes!!! Thats your 3pt lift hydraulic cylinder and not going to be cheap to fix..
I dont see how that would affect movement of the tractor.
It may just be low on fluid now? I’m guessing that a lot of fluid could get pumped out but may be off base on that.
@14Cwater - do you have any idea how that got damaged? Were you transporting something heavy on the three point hitch?
14Cwater
b 3030
Nov 10, 2024
florida
I was actually loading my generator into my truck bed with the front forks when everything stopped working.
14Cwater
b 3030
Nov 10, 2024
florida
I cant find it on messicks. Any chance you have their part number?
14Cwater
b 3030
Nov 10, 2024
florida
Did you have rear ballast on the 3pt? Something was putting pressure on that 3pt piston and it wasnt the loader/forks.
Dan,
I have a small rake that was on the back. I was doing hurricane clean up. I did just have it serviced and they added alot of hydraulic fluid. Could they have over filled it and created to much pressure?
