Yep, you guessed it......another "on the fly" use for the backhoe.
4,225
Well I "accidentally won" an auction for a "gunsmithing lathe" and had to go pick it up the other day.
The ride back to the cottage was "uneventful" but also uneasy. I had it strapped down "good enough" with ratchet straps and 2 chains, but the "top heavy'ness" made the ride back "uncomfortable".
Maybe it was just in my head, but there was this "constant nagging" in my head that if the base snapped it would be "lights out".
I decided to take it apart to transport it home (4 hours on the highway) and I wanted it up against the front rail so that when I hit the brakes it would not slide forward
I used the FEL to "dismount" it from the base, but needed to drag it forward about a few feet.
I tried to slide it by had, but "no bueno"
Then it hit me, "General Jackson" would work perfect
"Snug as a bug in a rug" and almost ready for transport.
A little more disassembly, and "re rigging" and it should be an "easy drive" today.
Reactions: 8 users
Yooper
3901 LA525
May 31, 2015
1,670
821
NE Wisconsin
Nice lathe you got there! Perfect size for a hobby lathe. How many hp?
Transporting lathes is a PIA. You done good to break it down because they are top heavy.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
232
250
Pennsylvania
Is that a shop Fox? I think Grizzly makes them. Nice lathe
L35
Jun 13, 2010
631
659
CT
Accidents happen!
4,225
Thanks guys!
Its a 2 hp......Not a "beast" by any measure, but it's 4 times the hp of my current Craftsman and 8X my Chi-Com mini...
Yep, Shop Fox.....I'm not sure if Grizzly makes/made them, but I am 99% positive it is a "re-branded Grizzly"
Not my "forever lathe" but a 'temporary upgrade".
The drive home was absolutely "worry free"
and offloading was a breeze.
The hardest part is backing my trailer into the garage.
Then I had to "drag it back" to the end of the trailer. So I hooked it to the hoist.
Then pulled forward until it was "dragged" to the end of the trailer.
Then lifted the hoist arms up and over the ramp. (only had 1/2 inch to spare)
Then put it on some of those HF furniture dollies just so I can move it around in the garage.
Now I gotta clean it up and figure out how to get it into the basement.
Marky
L2502DT, Ford3000
Oct 24, 2024
40
99
Georgia
You gonna use it to peel that box of taters that was sitting on the trailer? 🙂
3,234
Nice pick up.
Virtually identical to my Birmingham, slight differences in electrical button layout, headstock end cover, and work light.
See if you can find a thin sheet of slippery hard plastic to line the shelves in the base column cabinets.
If you store the chucks, faceplate, steady & follower rests in there, you'll thank me.
As for the move to the basement, this should work pretty well:
Seriously, however you decide to move it, pull the chuck, tailstock, end cover, work light, & tool post.
Every little bit of weight removed helps.
4,225
What does the plastic liner do?
And yes I plan to strip it down to "parade rest" before moving it.
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
241
280
CT
Thanks guys!
Many forget about using the lift arms to unload trailers and truck beds.
Enjoy the lathe…. Now you need a bridge port. Even more bulky to move. 🤦‍♂️😆Used to load a 43 ft step deck with lathes and mills. Lots of chains an blocks 🤣
Yooper
3901 LA525
May 31, 2015
1,670
821
NE Wisconsin
With 2hp you will have enough to enjoy the finish you can get out of carbide. Carbide likes speed and feed.
How big is the spindle through hole?
3,234
Chucks & stuff are heavy, door is small and at an awkward level, plastic just makes it easier to slide stuff out to the front.
A lot of stiction without it.
Mine was made from one of those large "wet floor" A frame signs that blew out of a truck on the freeway.
3,234
Should be 1 5/8".
3,234
If I remember right, my folding shop crane moved it pretty well (stable) when slung as shown below, and gave lots of easy "wiggle" when trying to line up the holes to bolt the base legs back on.
Mine doesn't have flood coolant, but I sealed the machine-to-chip pan interface with RTV, because maybe someday I might.
7,080
Since your thread title is ".another "on the fly" use for the backhoe"
I have one for you.
I have a 40' ladder I needed to get to the bill at the top of my barn. That ladder is too heavy and awkward to get it there myself. I anchored it to the backside of the backhoe bucket and set it in place. I anchored it so it would stay, no matter the wind. It's been stored there for 4 years now! ;)
4,225
Oh, nice neighborhood also. (y)
Thanks.
I liked it a lot when we moved there, but my life/views/hobbies have changed a lot in the 25 years we have been there.
I'm looking forward to the "OK" from SWMBO, for the "lets move" signal. 😉
