Dropped stick in L3800D Hydraulic Fill
Neverscaredfishing
Kubota l3800D
Nov 4, 2024
Seavee85
Accidentally had a piece of a stick break off and fall in the hydraulic fill of my l3800d. Not sure if it will harm anything in there or if there is a way to get it out. It’s about 3-4” long piece that broke off in there.
Jim L.
865
167
I'd get a small clawed parts grabbing tool and get the stick out of there. If it gets chewed up it will clog somewhere and that's bad.
8,790
WHY?
Why did you poke a stick in there?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,119
3,381
While It does suck, the sump screen and filter should prevent any damaging particles from running through the hydraulics. That's what they are for. I have found a lot of interesting things in oil pans. Nuts, bolts, washers and what I thought was a diamond. Turned out to be a fake. Which is probably why it fell out of the ring someone was wearing.
It would give me a bad feeling though. It will degrade over time. But.... filter should do its job. If you want it out then it's time to pull the pan.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,572
2,029
Western MT
I would try to snare it with wire. I agree I'd try really hard to get it out.
Neverscaredfishing
Kubota l3800D
Nov 4, 2024
Seavee85
Does the l3800d have a sump screen? Or is there a hydraulic pan that can be removed on the underside? Haven’t given up on trying to rush it out somehow but also wondering if it has a screen or removable pan
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
366
526
SE, NM
Make friends with a gynecologist.
Don't beat yourself up too bad. I way have used a stick a time or two for such things.
8,790
sheer stupidity….
Honest answers always gets a thumbs up! (y)(y)(y)(y)
Wood stick, it will float in the hydraulic fluid till the gears grab it and macerate it into pulp then send it to the filter.
Is this where you stuck the stick? (green)
If so it's in the rear end and the best way to get to it is pull the hydraulic cylinder cover and remove the stick.
Second option would be to remove the PTO cover and the PTO shaft (yellow) that will give you a pretty good hole (red) to fish it out.
Neverscaredfishing
Kubota l3800D
Nov 4, 2024
Seavee85
Wow, thank you for the detailed response! The green highlighted hole is the one I dropped it in. I like the idea of removing the pto cover and shaft. I do have a backhoe on the tractor and am wondering if firing it up to get the backhoe out is the way would macérate it or not. Would simply firing up the engine be ok or would that grind it up?
8,790
Yes you could start it with clutch in (clutch pedal pushed down) and NOT moving it and you would be fine.
The Gears in the rear only turn on movement, having the clutch pedal pushed in is a safety only.
This would allow you to move the BH hydraulicly.
If you need to move the tractor away from the BH after removal, I would suggest you do it manually (like pushing or pulling it, that way if the stick does get caught in the diff it should not do any damage.
One note: I would not do a normal fluid drain, that way if the sick is floating or broken it should not get moved to the front of the transmission.
Drain it from the rear axle cases, then after you've removed the stick then drain it from all other points.
3,649
Man, I air some dirty laundry sometimes, but just a little friendly FYI; next time you reveal something like that, make sure to blame it on your grandson. 😉🍸
Neverscaredfishing
Kubota l3800D
Nov 4, 2024
Seavee85
One more question, if i remove the top cover instead which seems like it would give the most access would the lifting arms need to be removed or would that all come up as a complete unit? Not sure what other disassembly is involved with removing the top cover but upon reviewing the diagrams and thinking that the stick would float im guessing the top would be the better option.
8,790
Yes you can remove the whole assembly as one piece.
I don't feel that it's too involved to remove that part and yes it would give you 100% access to that area.
